Robbie
Anmeldung: 29.06.2004
BeitragVerfasst: Do 03 Feb, 2005 10:43  Titel:  (Kein Titel)
und was is mim fit to screen?
memy
Anmeldung: 15.11.2004
BeitragVerfasst: Do 03 Feb, 2005 11:45  Titel:  (Kein Titel)
Es gibt ne neue Version.
February 2nd, 2005:
Added Skin Browser Screen
Added Gamma control (GammaControl or Gamma Panel)
Improved TouchWheel interface to support real buttons on it
Updated BrushMetal Skins with New TouchWheel design and volume sliders
Fixed Ampersand display "bug"
Improved Run/Launch functions to run application from their installation path (improved support for Routis and other apps)
Improved resume after Hibernation
Added prevention against Winamp File Dialog
Updated Config Tool with Gamma Options
Fixed Destinator GPS option to use the correct skin file
Improved Support for Album Art (Images) in sub-folders
Added support for Cue-Sheet Plugin
Und hier der Entwicklungsstand, der auch ein paar Fragen beantwortet.
Wobei die Auflistung auch Priorisierung der einezelnen geplanten Implementierungen wiedergibt - ...External LCD also zuletzt in Angriff genommen werden soll:
Skins: 100%
Audio Engine: 100%
Video Engine: 100%
Internal DVD: 100%
External DVD: 100%
Mixer Engine: 100% (Can be Improved)
Destinator 3: 100%
Launch Applications: 100%
SDK 100%
ID3 Support 0%
Phone Control 0%
Picture Viewer: 0%
MapPoint: 0%
Playlist: 0%
Radio: 0%
External LCD: 0%
memy
Robbie
BeitragVerfasst: Do 03 Feb, 2005 11:55  Titel:  (Kein Titel)
cooooooooooo!! Wo??
ach, okay... Sorry
http://guino.home.insightbb.com/download.html
memy
BeitragVerfasst: Do 03 Feb, 2005 21:58  Titel:  (Kein Titel)
@Robbie
"und was is mim fit to screen"
Ausm mp3car.com:
This acatually is a "skin" setting.....all you have to do is go into your skin folder and edit the GENERAL.INI file. There'll be two options in there "showheight" and "showwidth" just change them to whatever size you'd like to have the screen.....
hth
memy
Robbie
BeitragVerfasst: Fr 04 Feb, 2005 14:19  Titel:  (Kein Titel)
okay, das mim screen hat geklappt, aber wie schauts aus mit dem Mediaplayer?
Manchmal läd er alles Songs aus meinem Musik-Ordner, und manchmal klicke ich ein volles mp3-verzeichniss an und es läd garkein track rein...
(habe schon alle pls-files gelöscht, wird aber nicht besser)
komisch
crypto612
Anmeldung: 06.09.2004
BeitragVerfasst: Mo 07 Feb, 2005 11:25  Titel:  (Kein Titel)
UND M3U (playlisten) einlesen geht doch !!
habs rausgefunden wie man im road runner playlisten einlesen kann
und zwar folgendes:
stellt in der rrconfig.exe unter audiofiles einfach ".m3u,.mp3,.wma" und wenn jemand probleme mit wma files unter winamp hat kann er das wma auch einfach weglassen ..
so viel spaß noch
Gustel56
Anmeldung: 08.02.2004
BeitragVerfasst: Di 08 Feb, 2005 16:18  Titel:  RoadRunner & PhoneControl
Hi, wollte gerade anfangen mit meinem Freund ein ähnliches System wie mediacar zu programmieren, und siehe da, auf einmal gibts RoadRunner. Also wozu jetzt noch selber die Arbeit machen.
Allerdings sind da schon einige Fragen, vielleicht wisst ihr schon etwas damit anzufangen.
1. Da mein Radio extra ist, finde ich den Radio Button ziemlich überflüssig. Daher habe ich ihn mit PhoneControl belegt, leider startet das aber nicht embeded. Laut der Readme von RoadRunner sollte das folgendermaßen funktionieren: z.b "RUN;C:\WINDOWS\NOTEPAD.EXE;NOTEPAD"
wenn ich das auf phoneControl anwende reagiert es aber nicht darauf.
Sollte irgendjemand ne Ahnung haben wie das funktionieren soll, gebt mir bitte Bescheid.
2. Wie binde ich unter applications andere Programme ein? in der rrconfig.exe
kann ich ja einen launch pfad angeben. bei mir z.b c:\programme
wie kann ich nun ein programm aus der liste die mir nun gezeigt wird starten? ich möchte gerne nintendo emu´s laufen lassen die unter c:\programme\emulatoren liegen.
3. Wie funktioniert das mit dem Gamma einstellen.
Wäre super wenn irgendjemand eine antwort auf meine Fragen hätte.
und danke, dass sich endlich jemand diesem leidigen Thema mediacar - update angenommen hat.
Ach noch was, ich habe bei mir einfach nur road runner installiert und er läuft auch ohne mediacar davor installiert zu haben. s. Dateigröße des Packets > als bei media-car. also scheinbar voll integriert.
Danke schon mal für Anworten.
Gruß Gustel46 Crying or Very sad Crying or Very sad
memy
BeitragVerfasst: Di 08 Feb, 2005 21:30  Titel:  (Kein Titel)
Hi Gustel
1.
Das hatte ich mir genauso vorgestellt, da ich mir extra ein schickes dab Radio zugelegt habe und nicht mit diesen usb Dingern rumprobieren möchte. Ich habe mir das bis jetzt aber noch nicht weiter angesehen...
2.
Eingebundene Programme gehen glaube ich nur über diesen Weg:
- In dem Launch Ordner ein neues Verzeichnis anlegen für das Programm, dass du starten willst.
- Die .ini aus dem Calc Ordner in den neuen Ordner kopieren - alles entsprechend umbenennen und Pfad/WindowSearchString in der .ini anpassen.
- ggf. noch ein Bild dazulegen
zB:
[General]
PATH = C:\Windows\System32\mspaint.exe
TryEmbeddedTimeout = 5
WindowSearchString="Paint"
3.
Zur Gammaeinstellung mußt du wahrscheinlich erstmal die .ini anpassen:
- GammaControl.ini öffenen
- In 5 Gammawerten muß der Punkt durch ein Komma ersetzt werden.
zB
Day_Gamma=0,92 (statt 0.92)
- Dann kannst du über die GammaControl.exe (Taskleiste) die gewünschten Werte einstellen.
- Im Menü unten auf "Difine Values" gehen
- zB den Nachtwert über die Tasten einstellen
- und über Set night gamma abspeichern
- oder einfach die Werte in der .ini einstellen
memy
Gustel56
BeitragVerfasst: Di 08 Feb, 2005 22:10  Titel:  (Kein Titel)
@memy
Danke dir, also 2. habe ich gerade probiert. funktioniert allerdings auch nicht.
hast du bei dir mediacar auch noch drauf? wenn ja wie hast du dann roadrunner installiert,? ins mediacar verzeichnis? oder anderst herum? oder hast du auch nur road runner installiert. Das mit dem Gama muss ich nochmal einstellen, bei mir passiert da gar nichts, aber danke für die tipps.
Gustell
memy
BeitragVerfasst: Di 08 Feb, 2005 22:31  Titel:  (Kein Titel)
So weit ich weis gehts nicht ohne MediaCar.
Und RR einfach ins MC-Verzeichnis - genau
Also:
Winamp
MediaPlayerClassic
MediaCar
RoadRunner
installieren (in der Reihenfolge)
Danach kannst die die anderen Sachen mit Launch und Gamma Einstellung ja noch mal probieren.
hth
memy
Gustel56
BeitragVerfasst: Do 10 Feb, 2005 01:03  Titel:  (Kein Titel)
hab jetzt alles nochmal neu installiert. Also den Media Car benötigt man nur um extern. apps laufen zu lassen.
Habe jetzt alles hinbekommen, Gamma, externe Apps, das brushed metal skin habe ich geändert, jetzt habe ich statt radio einen telefon-button der phonecontrol startet.
Wenn alles ausgereift ist, stelle ich ne fertige Lösung, wie ich alles konfiguriert habe ins Netz. Und ein neues brushed-metal skin pack mit geändertem Startmenü.
Bis Denne
divemarc
Anmeldung: 23.09.2004
1991 BMW 3 Series
BeitragVerfasst: Do 10 Feb, 2005 12:14  Titel:  (Kein Titel)
Au ja, das fänd ich auch extrem fein Smile
Gustel56
BeitragVerfasst: Fr 11 Feb, 2005 02:27  Titel:  (Kein Titel)
So jetzt habe ich alles soweit fertig.
Die Bedingungen damit alles reibungslos funktioniert:
1. Mediacar installiert nach c:\programme\mediacar
2. road runner installiert nach c:\programme\mediacar
3. phone control installiert nach c:\programme\phonecontrol (sollte das nicht möglich sein, in der menü.xml im skin unter roadrunner, den pfad korrigieren
4. standard Auflösung 800x600 also die gestrechte Version
5. Vorerst nur das BMW Logo, wird aber voraussichtlich noch eine pst Datei kommen bei der man das wechseln kann.
Es handelt sich hierbei um das brushed metal skin mit blauer beleuchtung.
Änderung: statt dem Radio Button ein Phone Button der PhoneControl startet, und beim Beenden phone control minimiert und rr kommt wieder zum vorschein. Der Button kann mehr mals gedrückt werden, nach der ersten Ausführung bewirkt er nur noch, das pc wieder maximiiert wird.
Hier die Links.
1. Brushed Metal Skin für Road Runner.
www.heibu-tec.de/brushmetalbmwbluerr.rar
dies einfach in skins verzeichnis von mediacar
2. Brushed Metal Skin für Phone Control:
www.heibu-tec.de/brushedmetalbluepc.rar
Diese bitte hierhin entpacken:
c:\programme\phonecontrol\designs\
(sonst stimmen die Pfade der brushedmetaldesign.xml nicht mehr)
Damit der Phone Button auch so funktioniert wie oben beschrieben, muss im PhoneControl Verzeichnis in der phonectl.config.xml (Ich habe nicht die komplette Datei mit angehängt, da meine bereits für mein siemens konfiguriert ist
der eintrag bei main window folgendermaßen Aussehen.
<MainWindow>
<Window>0,0,800,600</Window>
<WindowToSwitchTo>Road Runner</WindowToSwitchTo>
<SpeechEnabled>True</SpeechEnabled>
<LogEnabled>True</LogEnabled>
<MediaPlayer>WMPlayer</MediaPlayer>
<MuteAnalogMic>True</MuteAnalogMic>
<MainVolumeOnCall restoreVolume="True">20%</MainVolumeOnCall>
<StartupMode>Normal</StartupMode>
<UseOSK executable="osk.exe">True</UseOSK>
<AutoHideTimeout>0</AutoHideTimeout>
<BuildAbsolutePath>True</BuildAbsolutePath>
<Standalone>False</Standalone>
<Ringtone />
<SMStone />
<UseTaskbar>False</UseTaskbar>
<CheckPhoneTimeout>20</CheckPhoneTimeout>
<PopupOnHide position="700,550" size="72,56" opacity="80" backColor="Black" buttonColor="Firebrick">True</PopupOnHide>
</MainWindow>
So ich hoffe es klappt, und es sind keine Fehler mehr drin, ist ja doch schon ein bisschen spät.
Gruß Gustel Very Happy
memy
BeitragVerfasst: Fr 11 Feb, 2005 08:33  Titel:  (Kein Titel)
Klasse Very Happy
Ich probiere das heute abend gerne mal aus Gustel - Danke!
Es gibt übrigens wieder ein Update.
February 10th, 2005:
TV/WDM Camera support (click HERE for plugin)
Added Remove Playlist Numbers option
Added prevention for a few girder commands
Added Disable File/Folder name format with ID3 tags
Added Minimize Road Runner as a skin command
Road Runner now shows on TaskBar
Ich versuche das Eingangsposting immer aktuell zu halten
memy
hexer83
Anmeldung: 16.02.2005
BeitragVerfasst: Mi 16 Feb, 2005 00:56  Titel:  Woher komme ich das Programm Phone Control???
Halli Hallo... hätte ma gerne gewusst woher ich das Programm Phone Control bekomme oder ist das schon mit in deinem Skin eingebunden???
Danke....
hexer83
BeitragVerfasst: Mi 16 Feb, 2005 01:02  Titel:  Wie installiere ich die Road Runner Updates???
Nochma HAlli Hallo... wie istalliere ich die RR updates bzw. wie kopiere ich sie richtig???
Ist es egal ob ich nur die Binäre Datei oder die Source Datei neheme, oder muss ich da auf was bestimmtes Achten was ich von beidem installieren muss???
Danke n ochma und Sorry für meine blöden Fragen ;oP
hexer83
BeitragVerfasst: Mi 16 Feb, 2005 01:51  Titel:  Soooooo... kann mir einer ma bei RR Config helfen???
Und weiter gehts mit der blöde Fragerei ;oP *hihi*
Also, kann mir einer ma erzählen in welcher Reihenfolge ich das alles genau installieren muss, was ich wo rein kopieren muss usw. und vorallem...wie ich den RR richtig configuriere...hab echt noch null plan davon, aber jeder fängt ja ma klein an, gelle??? ;o)
Also ich muss auf jeden Fall Media Player und Winamp installiert haben, dann muss ich mir die MediaCar Vollversion leden bzw. kaufen und dann, wie gehts weiter mit dem Road Runner und der Config von dem Teil???
Danke euch schon mal vielmals für eure Gedult und bitte bitte hilft mir, will den Quatsch endlich ans rennen kriegen;o)
Thanks...
Pierre
memy
BeitragVerfasst: Mi 16 Feb, 2005 08:03  Titel:  (Kein Titel)
Hi Pierre
Bin zwar selber neu hier, aber trozdem ein herzliches willkommen im Forum Very Happy
Nimms mir nicht übel, aber die Antworten zu deinen Fragen findest du fast alle hier in diesem Thread Wink
Also einfach mal ein wenig blättern und die Suche nutzen.
Der derzeitige Entwicklungsstand des Programms von guino:
Current Status of this Project:
Skins: 100%
Audio Engine: 100%
Video Engine: 100%
Internal DVD: 100%
External DVD: 100%
Mixer Engine: 100%
External GPS (Map Monkey, FreeDrive etc): 100%
SDK: 100%
Girder Control: 100%
ID3 Support: 100%
TV/Camera support: 100%
Radio: 0%
Phone Control 0%
Picture Viewer: 0%
MapPoint: 0%
External LCD: 0%
RoadRunner kannst du übrigens in einen beliebigen Pfad installieren. Zu dem download gehört auch die RRconfig.exe, über die du die wichtigsten Einstellungen ganz einfach vornehmen kannst ohne dich durch .ini's wühlen zu müssen.
PhoneControl wird wohl in den nächsten Tagen voll integriert sein, es gibt auch schon einige Leute, die die skins dafür erweitern/anpassen.
Wenn du mehr wissen möchtest sieh dir das Subforum vom mp3car.com an (Link im Eingangsposting)
memy
hexer
BeitragVerfasst: Mi 16 Feb, 2005 10:58  Titel:  (Kein Titel)
hmmm...tja aber mp3car.com is aber in englisch ;o( Da muss man sich ja voll anstrengen das zu schnallen und die hälfte der Worte muss ich mir zusammen Raten;oP
Aber ne Frage hab ich da noch... und zwar wird hier im Channel gesagt das man für RR eine Vollversion von mediaCar auf dem Rechner benötigt, ich meine aber auf mp3car.com gelesen zu haben das man MediaCar für RoadRunner nicht mehr benötigt, wie denn das nun damit???
Das ich MediaPlayer und Winamp haben muss is ja klar... wo ich bei der nächsten Frage wäre, wird nicht mit der RoadRunner Installation auch ein Winamp 2.9 oder so mitgeliefert so das ich meinen 5er Winamp nicht mehr brauche...hab gehört einige hatten Probleme mit dem Winamp5???
Zum Thema INI's...wo finde ich denn diesen Dateien, falls ich doch mal ran muss..da diese auf MP3car recht häufig erwähnt werden???
Hat Gustel56 in diesem Thread das mit dem Phone Call anstelle von Radio bereits verwirklicht...weil du meintest das das ert noch kommt in den nächsten Tagen???
memy
BeitragVerfasst: Do 17 Feb, 2005 00:29  Titel:  (Kein Titel)
Gelesen habe ich das auch - das war aber mehr eine Vermutung...
Probiers doch aus, dass würde mich auch interessieren.
nein - ist nicht dabei. Aber die dürfte bei Bedarf ja noch zu finden sein.
Allerdings nutze ich die aktuelle Winamp-Version - ohne Probleme.
Versuch dich erstmal mit den Einstellungen über die RRConfig.exe - damit kannst du eh alles Wesentliche einstellen. Wenn du RR installiert hast findest du reichlich inis Smile
PhoneControl:
Das bezog sich zB eher auf die super skins von febsperanza - und anderen :
memy
[ Zeit: 0.6237s ][ Queries: 48 (0.2082s) ][ GZIP Ein - Debug Ein ]
