memy
Anmeldung: 15.11.2004
BeitragVerfasst: Do 27 Jan, 2005 12:30  Titel:  Road Runner
Ein FrontEnd, dass ursprünglich auf MediaCar basierte, jetzt aber mittlerweile eine eigenständige Entwicklung von Guino ist.
Guino`s Homepage
Mirror: http://rmc.pimpedwheels.com
mp3car.com-RoadRunner-Subforum
RR installer
Aktuelle Version vom: 19.04.05
Changelog
guino hat folgendes geschrieben:
April 19th, 2005:
Added Keyboard Support for PhoneBook/CallLists
Added "GETFOCUS" command for skins/remote
Added Peveition against double clicks on empty areas
Improved Phoco support to close it propperly and faster
Improved Phoco support to auto reload SIM card (if any)
Improved Phoco support to Load PhoneCTL.PB.XML when internal addressbook is not yet present
Improved Phoco's Interfacing to prevent missing messages
Fixed Loading Call Lists From Phoco -- This does takes a few seconds
Fixed Phone's Signal Strength display (wrong scale)
Fixed fast highlighting buttons "bug" of badly defined skins
Fixed Flash and Clipping Window/Flash Regions to resize correctly
Fixed Girder/Video Player Issues from version 4-15
April 15th, 2005:
Added Phone Control Support (thanks Hematec)
Added "RELOADLIST" skin command for SDK/Remote
Added "PLUGIN" skin command to launch plugins
Added "RRVER", "RRPATH", "RRSKINPATH" commands
Added support to pull Indicator's statuses from SDK
Improved MM<->Mappoint Switch
Improved Application OSK for non-full screen use
Improved Config Tool to Size to Screen and more Embedable in RR
Improved on HORM support resuming
Fixed NEXT/PREV bug when using "MINUS1" on stopped music
April 1st, 2005:
Fixed another Shutdown Resume Bug
Fixed Screen Redraw Issue from 3-30
Fixed Radio Playlist Bug when using Card Reset
Fixed Skin Browser Showing ".." (sometimes)
Added Last Functions of Mappoint (100% now)
Added MappPoint Customization File (Optional)
Added GotoFirst/Last Skin commands
Improved Playlist Display of badly tagged songs
Improved "LIST" command (preventions)
Improved Album Image Loading Locations
March 30th, 2005:
Fixed OSK indicators bug (Shift/Caps)
Fixed Launch List Font Color Bug
Fixed Radiator 'Freq-' bug
Fixed Update bug when using Browser out of audio player
Fixed Shutdown Mute Bug
Improved Freq+/- to support broken freqs
Added Support to Reset PCI/USB TV Card
Added Support to Reset PCI/USB Radio Card
Added MapPoint Support at 90% (Major feature)
Added Video Player Crash prevention
Added Support to Rename Files using Folder Browser
Added Support to Delete Files using Folder Browser
Added support to change RR's skin labels through SDK
Added Skin Commands: "PAUSE", "RESUME"
Added Label Codes to Display GPS Info
Added Option to Reload List after hibernate (HORM support)
Added support to send keys to embbeded applications
March 19th, 2005:
Added support for Switching-Merging labels on Skins
Added Support to use button down/up events from Flash
Added Support for Flash/SDK to seek to song/video position
Added OSK search of Playlist and Folder's current list
Added Web Browsing support (FireFox and I.E.)
Fixed Minus1 List Update Bug
Added Error/Freeze Preventions
March 17th, 2005:
Added Flash Indicators Support
Added Flash Clipping Support
Added Support for SDK and Flash objects to send commands "as repeat"
Added "TODAY" label code for flash support
Improved Switching Data Labels to switch format as well
Improved AVS Vis support
Fixed smaller bugs
Made Config Tool delete Resume file
March 16th, 2005:
Added Switching Data Labels support
Added "SWITCHLABEL" dynamic skin command
Added OSK support for EMBBEDED applications
Added "LEFTTORIGHT" skin command (foreign support)
Improved Keyboard support
Improved clear playlist to stop winamp
Fixed OSK typing bugs from 3-15
March 15th, 2005:
Added option to allow all radio frequencies
Added Line IN plugin support for radio
Added Force-Hibernate option
Added Command Translation Table support
Added Keycode Tool for Keyboard Mapping
Added Skin commands: "CTRLLEFT", "CTRLRIGHT", "CTRLUP", "CTRLDOWN", "CTRLEXEC"
Improved Internationalization support to try keeping fonts
Improved Built-In Video player to jump in steps according to video lenght
Improved LazyTag option to not display the path of songs
Fixed Hibernate Loop bug
Fixed Resume Music Bug on Hibernate
March 12th, 2005:
Added Full Native Keyboard Support
Improved AVS plugin to remove its borders
Fixed Current Song display in playlist bug
Fixed 60Hz Save/Load Preset bug
Fixed Girder use of Select/+/Browse/Back in launch screen
Fixed Issue with first folder list display
March 11th, 2005:
Added support to load/save Mixer Presets
Added support for Merging Data Labels
Added Skin commands: "DAYGAMMA", "DAYSKIN", "NIGHTGAMMA", "NIGHTSKIN" and "TAGTITLE"
Improved Resume Playing function
Fixed TAG display issue with files without tags
March 10th, 2005:
Added LazyTag option (for faster scrolling)
Fixed Shutdown resume "bug"
Fixed Various DVD player issues
Fixed "TAGxxxx" on playlist changes
Fixed BROWSE.RRL being added to playlist bug
Improved Tag Loading/Display Performance
Less Invasive Hibernate function
March 9th, 2005:
Added BROWSE.RRL file support
Added "go home" browse feature
Fixed DVD issue from version 03-08
Fixed some Video Confinement issues
Improved embbeding to "cut" single line borders
March 8th, 2005:
Added Skin Commands: "NEXTTRACK", "PREVTRACK", "RRNEXT", "RRPREV"
Added Support for Confining Video in a screen position
Added "remember last skin" feature
Fixed Radiator support in foreign Regional Settings
Fixed MapSonic Wave Fix Support
March 6th, 2005:
Radio Support at 90%
Fixed Multiple Button Highlight Bug
March 2nd, 2005:
Improved Winamp Startup
Fixed DVD Seekbar Bug
Fixed Day/Night skin font bug
Fixed another Girder issue in video player
Fixed (?) Dual font problem
February 27th, 2005:
Added Skin Clipping definition to allow weird shape skins
Added Multiple command support for buttons
Added Scan Feature
Added Day and Night Skin support
Added Option to hide taskbar
Fixed Shuffle/Repeat bug after hibernation
Fixed need of two clicks when using touchscreen
Fixed Overspeed indicator bug
Fixed Image reset when changing songs on launch screen
Updated Config Tool
Other smaller bug fixes
February 23th, 2005:
-Built in Video Player (without MPC)
-Fix for Hide mouse after Hibernation
-Added prevention from running same screen twice using SDK or remote
-Added Scan function (for MP3, TV and future radio)
-Various Bug Fixes
There's no built in support for playing DVDs, so either use MPC or an external player.
Projektstatus:
Skins: 100%
Audio Engine: 100%
Video Engine: 100%
Internal DVD: 100%
External DVD: 100%
Mixer Engine: 100%
External GPS (Map Monkey, FreeDrive etc): 100%
Launch Applications: 100%
SDK: 100%
Girder Control: 100%
ID3 Support: 100%
TV/Camera support: 100%
Radio: 100%
MapPoint: 100%
Phone Control: 90%
Base Plugin: 90%
Picture Viewer: 0%
External LCD: 0%
memy
manu
Anmeldung: 24.08.2004
1997 Honda CR-X
BeitragVerfasst: Do 27 Jan, 2005 12:58  Titel:  (Kein Titel)
Läufts denn bei dir?
Bei mir kommt immer ein Fehler!
Gruß Manu
wizZzard
Anmeldung: 13.12.2004
1998 Volkswagen Golf
BeitragVerfasst: Do 27 Jan, 2005 19:28  Titel:  (Kein Titel)
funzt
Fehler 429 ist auf meinem großen Rechner weg, jetzt mal auf CarPC testen! Smile
Bounty_Hunter
Anmeldung: 12.01.2005
BeitragVerfasst: Do 27 Jan, 2005 21:15  Titel:  (Kein Titel)
ist das jetzt ein komplettes Programm oder nur ein Mod von Media-Car?!
manu
1997 Honda CR-X
BeitragVerfasst: Do 27 Jan, 2005 21:19  Titel:  (Kein Titel)
Und das beste: Es ist OpenSource!!!
wizZzard
BeitragVerfasst: Do 27 Jan, 2005 21:49  Titel:  (Kein Titel)
also ReMediaCar ist nur ein Mod! Zum Ausführen brauchst du noch das Orginale. Ich habs jedenfalls drüber kopiert! Smile
memy
BeitragVerfasst: Do 27 Jan, 2005 22:09  Titel:  (Kein Titel)
Ja, ohne das Original gehts nicht.
Der Thread im mp3car ist dazu auch lesenswert.
Splasher
BeitragVerfasst: Fr 28 Jan, 2005 15:19  Titel:  (Kein Titel)
auf meinem Heim-PC gehts auch einwandfrei... bin begeistert!!!
jetzt noch auf den carpc und dann abdafür!
erazor
Anmeldung: 15.07.2004
1999 Audi S4 Avant
BeitragVerfasst: Fr 28 Jan, 2005 15:47  Titel:  (Kein Titel)
könnt ihr mal kurz beschreiben, wie ihr das gemacht habt?!
was hat sich denn zum mediacar verändert?!
fuchs
BeitragVerfasst: Fr 28 Jan, 2005 18:01  Titel:  (Kein Titel)
Oh, das ist so ziemlich genau das, was ich auch gerade programmiere...
memy
BeitragVerfasst: Fr 28 Jan, 2005 22:57  Titel:  (Kein Titel)
Erzähl mehr fuchs Smile Was machst du genau? Was möchtest du implementieren? Wie weit bist du?
@erazor
In der neuen Version (von heute) ist eine kleine exe dabei, die die nötigen Einstellungen der Pfade usw übernimmt - vielleicht hilft dir das ja weiter!?
Ansonsten muß noch der skin angepasst werden. Das alles in den Pfaden der Originalversion.
Weiter bin ich leider auch noch nicht - bin auch eben erst mit dem probieren angefangen.
memy
fuchs
BeitragVerfasst: Sa 29 Jan, 2005 03:22  Titel:  (Kein Titel)
@memy:
ich bin noch weit, weit entfernt von dem, was remediacar kann.
bis jetzt ist es nur ein frontend mit den üblichen funktionen für den mediaplayer, d.h. man kann bilder, mp3's, avi's und sonstige multimediadateien wiedergeben.
wie bei remediacar ist die menüstruktur sehr flexibel: man kann sich selber neue menüs erstellen mit beliebigen objekten in (fast) beliebiger anzahl., außerdem kann man skins anderer car-pc anwendungen verwenden. (dabei muß natürlich das urheberrecht beachtet werden)
geplant ist unter anderem die einbindung von verschiedenen io-karten und ein integrierter dvd-player.
wenn ich etwas weiter bin, mach ich mal einen eigenen thread dazu auf und gebe eine testversion zum download frei.
gruß,
fuchs
memy
BeitragVerfasst: So 30 Jan, 2005 00:00  Titel:  (Kein Titel)
Hier ist noch eine kleine Installationsanleitung -zumindest hat es bei mir so funktioniert Confused
Falls ihr noch Ergänzungen/Änderungen habt - immer her damit.
Installation:
- Winamp muß vorhanden sein
- Media Player Classic muß vorhanden sein
- Originale Media Car Installation muß vorhanden sein
- Komplette Skins / Skin-Updates downloaden (an Road Runner angepasste Skins!)
- Road Runner Dateien in einen beliebigen Ordner extrahieren
- RRConfig.exe starten und anpassen
- ggf. das Skin-update in den entsprechenden originalen Skin-Ordner extrahieren.
Ansonsten:
= War es bei manchen Installationen notwendig, dass Winamp im MediaCar-Ordner liegt
= Dran denken, dass die Pfade in den .ini`s mit einem "\"- Backslash abschließen
= Je nach Ländereinstellung kenn es vorkommen, dass die LCD-Schrift _wesentlich_ zu groß dargestellt wird.
- Dann müssen eventuell in allen .skin Dateien die Fontgrößen angepasst werden.
- Dazu in den .skin Dateien nach allen (!) "LCD Display Grid" Angaben suchen und die Größenangabe, die direkt davor steht, ändern.
- Sie ist mit 17.5 angegeben und genau der Punkt ist das Problem -ein Punkt ist halt kein Komma Wink. Also entweder auf 17 oder 18 abändern.
@fuchs
da freu ich mich schon drauf Smile Ich finde das beeindruckend wieviel Arbeit und Energie einige Leute in solche Projekte stecken. Und natürlich auch vom Ergebnis Very Happy
memy
memy
BeitragVerfasst: Mo 31 Jan, 2005 20:23  Titel:  (Kein Titel)
guino (von dem Road Runner ist) hat gleich gestern abend noch eine neue Version rausgebracht, in der MapMonkey (Destinator) embedded läuft.
Habe es gerade ausprobiert - funktioniert prima.
Einfach die neuen Dateien über die alten kopiert und die Installation über die Config.exe angepasst...
memy
Robbie
Anmeldung: 29.06.2004
BeitragVerfasst: Di 01 Feb, 2005 08:48  Titel:  (Kein Titel)
jo, die version kann sich echt sehen lassen. werde den roadrunner wohl jetzt auch nur noch nutzen.
Robbie
BeitragVerfasst: Mi 02 Feb, 2005 20:16  Titel:  (Kein Titel)
memy hat folgendes geschrieben:
oje, kann das mal jemand fixen? bin zu faul, oder welche files sind das denn?
dann mach ichs halt...
memy
BeitragVerfasst: Mi 02 Feb, 2005 21:11  Titel:  (Kein Titel)
@Robbie
Hast du denn das Problem mit dem wesentlich zu groß dargestelltem lcd Font (~2 Zeilen auf 7")?
Die .skin Dateien liegen unter:
\RoadRunner\Skins\DEIN SKIN\xxx.skin
Einfach mal alle durchgehen - dauert nur ein paar Minuten Wink
memy
kare123
Anmeldung: 01.11.2004
BeitragVerfasst: Mi 02 Feb, 2005 23:34  Titel:  (Kein Titel)
So ich hab jetzt auch mal ne frage zu dem Road Runner MOD wenn man das so nennen kann Rolling Eyes .
Wie kann ich die *.m3u wieder sichtbar machen und wie kann ich die lieder wieder aus der playliste nehmen?
Ach ja weiß einer von euch wie man Travelbook im Fenster eingebunden zum laufen bekommt?
Robbie
BeitragVerfasst: Mi 02 Feb, 2005 23:37  Titel:  (Kein Titel)
okay, wie kann ich den Roadrunner so einstellen das er quarsi "fit to screen" ist?
gruß robbie
Michel
Anmeldung: 05.12.2004
BeitragVerfasst: Do 03 Feb, 2005 10:24  Titel:  (Kein Titel)
So,
ich habe Roadrunner nun auch installiert und bin begeistert.
  • MP 3s laufen einwandfrei (war zuvor jedoch auch schon so)
  • Videos laufe problemlos embedded mit dem Mediaplayer Classic
  • Das gleiche gilt für DVDs (ebenfalls embedded)
  • Map Monkey alias Destinator3 nun endlich auch embedded incl. Winamp Scahltflächen
  • Das starten externer Programme via LAUNCH funktioniert wie zuvor auch
Nun zu den Dingen, die ich vermisse:
  • Leider funktioniert die Eingabe und Bedienung via Tastatur nicht mehr, eine Nutzung des Gamepads als Eingabegerät ist so leider nicht möglich.
  • Das Switchen zwischen Tag-/Nachtdesign ist nicht möglich. Eine Lösung via 2. Skin wäre schön, übergangsweise wäre ich jedoch auch mit der Gammareduzierung zufrieden.
  • Das Auswählen der erstellten MP3 Playlisten ist nicht mehr möglich, es geht zwar auch indem man ein File im entsprechendem Ordner auswählt, jedoch ist die Auswahl eines *.m3u Files komfortabler.
Hat jemand für die o.g. Punkte schon Lösungen parat?
[ Zeit: 1.6984s ][ Queries: 47 (0.4983s) ][ GZIP Ein - Debug Ein ]
