6Ner
Anmeldung: 13.03.2006
BeitragVerfasst: Mo 27 März, 2006 14:27  Titel:  Messen der Wirkleistung eines Systems?!
Hab mir nach langem Überlegen doch ein µ-ATX Board von
Asrock geholt.
Hier mal die Daten:
CPU - 754-Pin Socket supporting advanced 64-bit AMD Athlon 64 and 32-bit / 64-bit Sempron processors
- Supports AMD's Cool 'n' Quiet Technology
- Chipset capable to FSB 1 GHz (2.0 GT/s)
- Supports Untied Overclocking Technology
- Supports Hyper-Transport Technology
Chipset - Northbridge: nVidia GeForce 6100
- Southbridge: nVidia nForce 410 MCP
Hybrid Booster - CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
Memory - 2 x DDR DIMM slots
- Supports DDR400 / 333 / 266
- Max. capacity: 2GB
Expansion Slot - 2 x PCI slots
- 1 x PCI Express x 16 slot
- 1 x PCI Express x 1 slot
- 1 x AMR slot
Graphics - Integrated NV44 graphics DX9.0 VGA
- Pixel Shader 3.0
- Max. shared memory 128MB
Audio - Realtek ALC850 7.1channel AC'97 audio codec
LAN - Realtek PHY RTL8201CL
- Speed: 10/100 Ethernet
- Supports Wake-On-LAN
Connector - 2 x Serial ATAII 3.0 Gb/s connectors, support RAID 0, 1, JBOD
(No support for "Hot Plug" function)
- 2 x ATA133 IDE connectors (support 4 x IDE devices)
- 1 x Floppy connector
- CPU/Chassis FAN connectors
- 20 pin ATX power connector
- 4 pin 12V power connector
- CD in header
- Front panel audio connector
- 2 x USB 2.0 headers (support 4 USB 2.0 ports)
Rear Panel I/O ASRock 8CH I/O
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x VGA Port
- 1 x Parallel Port (ECP/EPP Support)
- 4 x Ready-to-Use USB 2.0 Ports
- 1 x RJ-45 Port
- Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
BIOS Feature - 4Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- SMBIOS 2.3.1 Support
Support CD - Drivers, Utilities, AntiVirus Software
Accessories - Quick Installation Guide, I/o Shield
- Floppy/ATA 133 cables
- 1xSATA data cable
- 1xSATA 1 to 1 power cable
- 1xCOM port bracket
Form Factor - Micro ATX Form Factor: 9.6-in x 8.0-in, 24.4 cm x 20.3 cm
OS - Microsoft Windows 2000/XP/XP 64-bit compliant
Certifications - FCC, CE, MS WHQL
Dazu noch die passende CPU:
AMD Sempron 64Bit 3100+
Palermo (90 nm SOI)
Early models (stepping D0) are downlabeled "Oakville" mobile Athlon64
L1-Cache: 64 + 64 KB (Data + Instructions)
L2-Cache: 128/256 KB, fullspeed
MMX, 3DNow!, SSE, SSE2
SSE3 support on E3 and E6 steppings
AMD64 on E6 stepping
Cool'n'Quiet (Sempron 3000+ and higher)
Enhanced Virus Protection (NX bit)
Integrated DDR1 memory controller
Socket 754, 800 MHz HyperTransport
VCore: 1.4 V
First release: February 2005
Clockrate: 1400 - 2000 MHz
128 KB L2-Cache (Sempron 2600+, 3000+, 3300+)
256 KB L2-Cache (Sempron 2500+, 2800+, 3100+, 3400+)
Steppings: D0 (Part No.: *BA), E3 (Part No.: *BO), E6 (Part No.: *BX)
Dann noch ne Samsung 2,5 HD
Samsung SpinPoint M MP0402H - Festplatte - 40 GB - ATA-100 Puffergröße 8 MB Formfaktor 2.5" Typ Festplatte - intern 5400rpm
Möchte noch über USB ein SlimLine Laufwerk holen DVD.
2x 512 PC400 DDR Ram
Lilliput sollte wenn möglich ans boardnetz.
Hab z.Z. alles noch an einem normalen ATX-Netzteil.
Gibt es eine Möglichkeit die aufgenommene Leistung
über das Netzteil per Software festzustellen?
könnte ja auch den Strom messen mit hilfe eines
Multimeters. Dies mit der Spannung 230V multipliziern
und schon hätte ich die aufgenommene Scheinleistung.
Jedoch interessiert doch wohl die Wirkleistung oder?
Für zum dimensionieren des DC DC Wandlers?
Wie bekomm ich also eine genaue Wirkleistungsangabe
von meinen verbauten Komponenten????
Wollte mit evtl. das M2-ATX holen da stellt sich die
Frage ob die 160W reichen, da ich noch mit
dem Gedanke spiele eine Low-Profil Grafikkarte
nachzurüsten, da die 6100 onboard nicht wirklich der
Renner ist. Dachte an ne Aopen 6600 Passiv gekühlt
Low Profil.
Danke im Vorraus
Marius
Achja suche noch ne Software zum abspecken von XP
was könnt ihrm empf. für ein mglichst schnellen Start
von XP (nicht aus dem Ruhenzustand).
BeitragVerfasst: Mo 27 März, 2006 14:34  Titel:  (Kein Titel)
Kukscht du hier. Is aber nur näherungsweise.
http://www.extreme.outervision.com/
masterchris_99
Anmeldung: 27.10.2005
BeitragVerfasst: Mo 27 März, 2006 14:36  Titel:  (Kein Titel)
Also wenn musst du jede Volt Leitung die aus dem NT in den Computer geht nachmessen auf Ampere und diese Ampere zahl multiplizierst du mit der Volt Anzahl und dann hast du deine Watt. z.B. auf der 12 Volt Schiene sind 3A dann hast du da 36 Watt verbrauch.
Einfacher wäre es aber eine Stromzange zu besorgen oder ein Watt-Messgerät
newevent
Anmeldung: 31.08.2004
BeitragVerfasst: Mo 27 März, 2006 15:10  Titel:  (Kein Titel)
Verdammt hättest das nicht früher schreiben können?`Hab mir gestern so ein ähnliches System bestellt.
Was heißt die graka auf dem board ist nicht der Hit? Google sagt das zwar auch, aber 75 Mio Transistoren können wohl nfsu 2 oder andere games zum laufen bringen?
Außerdem reden wir von einer onboard graka, die nicht gerade die neusten Funktionen unterstützt und somit recht Strom sparend ist.
So wie du das System jetzt hast dürfte es keine Problem mit dem M2-ATX geben. Wenn du dir extra eine Aopen 6600 holst wird das evtl. eng.
Am besten testen und wenn durch die graka der Stromverbrauch außerhalb des M2 liegt... wieder zurückschicken.
BS177
Anmeldung: 12.04.2004
BeitragVerfasst: Mo 27 März, 2006 16:57  Titel:  (Kein Titel)
Näherungsweise ist echt gut. Rolling Eyes Habe mein Heinsystem mal eingetragen. Da stehen doch 436Watt. Ich komme laut einem Watt-Messgerät wären eines 3D Mark 2006 gerade mal auf 226Watt... Shock
Ich glaube das ist für den CarPC nicht wirklich nutzbar...
Bernd
6Ner
BeitragVerfasst: Mo 27 März, 2006 20:09  Titel:  (Kein Titel)
Gerade NFS2 habe ich probiert zum Laufen zu bringen.
Es funzt auch aber extrem schlechte Bild Qualität.
Die 6100 Onboard als eine 3D Karte zu nutzen ist schlicht
weg falsch. Des weiteren mit den Shared Memory bin ich
auch net so zufrieden. Wie die Speicheranbindung aussieht
ganz zu schweigen.
Sonst super Karte aber nur für Office.
Für Spiele wie NFS2 muss auf jeden Fall ne gescheite
Grafikkarte her. Ob da ne 6200 reicht wage ich zu be-
zweifeln. Bin schon die ganze Zeit auf der suche nach
ner Low Profil Passiv gekühlt.
und da fand ich bis jetzt nur die von AOpen.
Nur ob ich die 160W überschreite kann ich net sagen.
müsste man mal Aopen fragen was die so verbruzzelt.
MFG Marius Damm
Achja nach der oben genannten Homepage komme ich auf
162W. Werde wohl mal alle Schienen nachmessen.
Kennt jemand ne Software zum abspecken von XP?
BeitragVerfasst: Mo 27 März, 2006 21:38  Titel:  (Kein Titel)
BS177 hat folgendes geschrieben:
Bernd
Selbst während nem Benchmark wirst du nie die volle Leistungsaufnahme ausschöpfen.
Auf der Seite werden die vom Hersteller vorgegebenen maximalen Werte angegeben.
Die 436 Watt die bei dir raus kamen sind wohl richtig, als der Wert den dein System im wirklich allerschlechtesten Falle aufnimmt. Aber den wird man wohl nie erreichen.
BS177
BeitragVerfasst: Di 28 März, 2006 11:18  Titel:  (Kein Titel)
Der 3D Mark sollte aber schon recht nahe kommen, da die CPU + GPU unter Volldampf laufen und das die größten Stromfresser im System sind. Ist ja auch egal, bin froh das mein System nicht so viel schluckt...
Bernd
BeitragVerfasst: Di 28 März, 2006 11:33  Titel:  (Kein Titel)
Bernd
Klar, aber die ganzen anderen Verbraucher (HDD, DVD, USB, ...) werden dabei kaum oder gar nicht benutzt. Kleinvieh macht auch oft Mist Wink
Denke wenn man eine PSU mit etwa 70 % des auf der Seite ermittelten Wertes nimmt fährt man sicher
-Ice-
Anmeldung: 22.10.2005
BeitragVerfasst: Di 28 März, 2006 12:47  Titel:  (Kein Titel)
Bernd
da hat der Bernd recht. Allein 4 usb Geräte können bei 5V 2A ziehen. Sind schonmal 10 Watt die evtl. benötigt werden.
bye
newevent
BeitragVerfasst: Di 28 März, 2006 13:01  Titel:  (Kein Titel)
Jep nightmare hat recht ca. 30% weg rechnen... ist ein gute seite Wink
Von der theorie her müsste man mit 85Watt hinkommen
BeitragVerfasst: Di 28 März, 2006 13:13  Titel:  (Kein Titel)
-Ice- hat folgendes geschrieben:
bye
Bernd hat recht?
Daß die ganzen anderen Verbraucher nicht benutzt werden, war auf den Benchmark bezogen. Ich wollte damit ausdrücken, daß man sie trotzdem in die Berechnung für den Strombedarf eines PC mit einbeziehen muss.
BS177
BeitragVerfasst: Di 28 März, 2006 13:42  Titel:  (Kein Titel)
bye
Meine USB-Geräte hatte ich garnicht mit angegeben. Nur CPU, HDDs, Graka, Soundkarte, Lüfter, optische LWs und Speicher...
Hatte wohl noch einen Fehler drin. Habe Dual-CPU angegeben statt Singel-CPU, da ich ja eine Dual-Core CPU habe. Die Seite rechnet dann aber sicher als wenn ich 4 CPUs verbaut hätte. Komme jetzt auf 322Watt. Was ja deutlich dichter ran kommt.
Bernd
[ Zeit: 0.7103s ][ Queries: 47 (0.2530s) ][ GZIP Ein - Debug Ein ]
