cirovi2
Anmeldung: 19.02.2007
BeitragVerfasst: Fr 09 Nov, 2007 19:53  Titel:  Import POi in Navigator sometime not work..
I have a problem when import some POI in Navigator 2.
But with only a few categories.
With many other categories all worked well
They are imported regularly in showgps, the conversion start and work but in the end I get the error "file not found" 75.
The POI files . cat and. owm are created but remain in the directory of poiimportconsole.
If i manually move it in the navigator POi directory i not seen it on the map...
Can help me ?
ShowGPS
Partner
Partner
Anmeldung: 24.02.2005
BeitragVerfasst: Fr 09 Nov, 2007 23:02  Titel:  (Kein Titel)
Hello!
Please have in a look in the log.txt in the path of "poi import console" or post it here.
Regards,
ShowGPS
cirovi2
BeitragVerfasst: Sa 10 Nov, 2007 17:09  Titel:  (Kein Titel)
The log.txt exist but are empty.
In the input.txt i can see the Poi ...
The files . cat and. owm exist in the POI directory, too.
ShowGPS
Partner
Partner
BeitragVerfasst: So 11 Nov, 2007 19:51  Titel:  (Kein Titel)
Hello!
Ok.
Please edit the POIImportConsole.ini and set LogLevel to 0.
After this start manually POIImportConsole.exe again.
Now have a look in the log.txt. I think a poi-entry is corrupt.
Regards,
ShowGPS
cirovi2
BeitragVerfasst: Mo 12 Nov, 2007 20:33  Titel:  (Kein Titel)
I resolved, the file input.txt contained errors, thank you.
I did not understand if it is the same thing to import the POI using the "poi setting" or "import poi" you can explain ? Thanks.
Because now I have 15 categories of poi in Navigaor_poi divided into separate folders (eg Navigator_poi_autovelox) every folder with the two files .cat and .owm but not all are displayed in the map, only the first folder...I have something wrong?
(_ = Backslash)
ShowGPS
Partner
Partner
BeitragVerfasst: Mo 12 Nov, 2007 21:31  Titel:  (Kein Titel)
Hello!
The export in "poi settings" and "poi import" is the same.
But in poi import the export goes automatically, when you update your pois.
What happen, when you have only two or three of the folders in the poi-folder of navigon?
What is the error in the input.txt? Can you post it? Then i can filter this error in the next version.
Regards,
ShowGPS
cirovi2
BeitragVerfasst: Di 13 Nov, 2007 09:56  Titel:  (Kein Titel)
Whit only three folders all work well.
I divided the poi by speed limit 30/50/60/80/90/130/over how can I do to keep "minipoi window" division and unite them all into a single file for "generic autovelox" in navigator ?
For the input.txt I remade the whole procedure and deleted files, sorry.
ShowGPS
Partner
Partner
BeitragVerfasst: Di 13 Nov, 2007 21:32  Titel:  (Kein Titel)
Hello!
Please zip all your poi-folders in navigon and send it to support at showgps.de. Then i look what happen in navigon.
ShowGPS has no function to unite poi-groups to one export-file.
You must import the pois in one group in ShowGPS and make the export to navigon after this.
To import all in one group, rename all files in the same name and import them one after the other without the "POI-Update" option.
What you mean with the division of the "minipoi window"?
Regards,
ShowGPS
Amigo1981
Anmeldung: 26.10.2007
BeitragVerfasst: Di 20 Nov, 2007 12:50  Titel:  (Kein Titel)
Bei mir gehts auch nicht. Gibts da schon was neues? Wenn nur 3 Ordner im POI verzeichnis sind, gehts problemlos. Wenn da mehr als drei sind, werden immernoch nur diese drei angezeigt.
Ist es vielleicht möglich nur die styles.txt und die input.txt zu exportieren, sodass man diese dann von Hand ändert? So könnte man per copy paste selbst eine input und style erstellen, welche man mit dem poiconverter dann in die entsprechenden Dateien umwandeln könnte.
Gruß, Amsigo1981
ShowGPS
Partner
Partner
BeitragVerfasst: Di 20 Nov, 2007 21:36  Titel:  (Kein Titel)
Ja, es gibt eine Lösung die ich zusammen mit cirovi2 getestet habe.
Eine erste neue BETA gibt es hier zum Download: http://www.showgps.de/download/ShowGPS.exe
Dabei muß zunächst bei jeder POI-Gruppe die exportiert werden soll, der Haken bei "Nav-Software Update" gesetzt werden (Übernehmen nicht vergessen).
Danach kann dann der Button "Export" betätigt werden und alle POI-Gruppen werden gleichzeitig nach Navigon exportiert. In Navigon gibt es dann eine neue Kategorie "ShowGPS" und die POI-Gruppen als Unterkategorie.
Da es noch in der Beta ist, könnt ihr es testen...eventuell fällt noch was auf.
ShowGPS
Mario K.
Anmeldung: 06.10.2005
BeitragVerfasst: Mi 21 Nov, 2007 08:08  Titel:  (Kein Titel)
Guten Morgen,
könntest du es bitte so einrichten, dass statt "ShowGPS" als Verzeichnisnahme, der Name der Kategorie übernommen wird ?
Danke u. Gruss
Mario
Amigo1981
BeitragVerfasst: Mi 21 Nov, 2007 12:27  Titel:  (Kein Titel)
Es geht jetzt richtig gut. Dass die Kategorie angezeigt wird, wäre an sich besser, da mit den ganzen einzelnen Blitzern die Übersicht verloren geht. Aber ich denke, wenn jetzt jede Kategorie einzeln exportiert wird, kommt man wieder über die drei Kategorien im POI-Ordner und ein Teil wird wieder nicht mehr angezeigt... Ist im Navigator irgendwie dumm gelöst...
Mario K.
BeitragVerfasst: Mi 21 Nov, 2007 13:59  Titel:  (Kein Titel)
@ Amigo1981
dieses Problem kenne ich nicht.
Ich habe sämliche Kategorien welche von den Navifriends angeboten werden (14 Ordner) im POI-Verzeichnis und es wird alles angezeigt.
Gruss
Mario
ShowGPS
Partner
Partner
BeitragVerfasst: Do 22 Nov, 2007 00:17  Titel:  (Kein Titel)
Bitte testet nochmal eine neue Version.
Das mit den Kategorien ist an sich kein Problem. Frage ist nur ob man trotz der Kategorien nicht die Übersicht verliert.
Jetzt werden alle POIs noch unter ShowGPS aufgeführt...und außerdem unter der jeweiligen Kategorie.
@Mario K.
Hast du NavigatoR2 oder NCK5?
ShowGPS
P.S. Außerdem ist jetzt die direkte Navigationsanwahl für Navigon über ShowGPS möglich...siehe dazu anderen Thread.
Amigo1981
BeitragVerfasst: Do 22 Nov, 2007 00:51  Titel:  (Kein Titel)
Genial! So, wie man sich das wünscht! Gute Arbeit und großes Dankeschön!
Wenn das jetzt noch mit der 302u und aktuellem Treiber gehen würde, wäre die Welt komplett in Ordnung für mich.
@Mario K.
Soweit ich weiß, gibts von den Navifriends gleich ne POI.cat dazu, mit der das dann wohl gehen könnte. Bin von den angebotenen POIs der Seite net ganz so angetan.
Gruß, Amigo1981
Mario K.
BeitragVerfasst: Do 22 Nov, 2007 08:37  Titel:  (Kein Titel)
ShowGPS hat folgendes geschrieben:
@Mario K.
NCK5
Amigo1981 hat folgendes geschrieben:
@Mario K.
Soweit ich weiß, gibts von den Navifriends gleich ne POI.cat dazu...
Diese POI.cat kannst du in jedem Editor bearbeiten und auf deine Bedürfnisse anpassen.
ich auch nicht, aber es war ja bisher nichts anderes zu bekommen Laughing
aber mit ShowGPS können wir uns jetzt auch noch alle SEX-Shops anzeigen lassen Laughing
Gruss
Mario
ShowGPS
Partner
Partner
BeitragVerfasst: Do 22 Nov, 2007 09:21  Titel:  (Kein Titel)
Wohin ihr wollt müßt ihr wissen... Smile
Aber damit ist klar, warum du mehr angezeigt bekommst. NCK5 scheint damit etwas anders umzugehen....
(ShowGPS unterstützt standardmäßig kein NCK5!)
Dann viel Spaß damit.
ShowGPS
Mario K.
BeitragVerfasst: Do 22 Nov, 2007 12:14  Titel:  (Kein Titel)
Danke Smile
werde ich die Tage mal ausgiebig testen.
Gruss
Mario
Mario K.
BeitragVerfasst: Fr 23 Nov, 2007 08:07  Titel:  (Kein Titel)
Guten Morgen Smile
ShowGPS bricht am Ende des Exportiervorgangs mit einer Fehlermeldung "Error..."
und noch irgendwas ab. Hat jedoch, in dem von mir in der POIImorterConsole
angegebenen Pfad, eine "POI.OVM" u. eine "TEMP.CAT" erstellt.
Input- und Styles.txt sind vollständig. Die POIImorterConsole kann damit auch
weiterarbeiten und die erforderlichen .cat u. .ovm erstellen.
Wenn ich nun den Inhalt der von ShowGPS erstellten TEMP.CAT in die POI.CAT
von NCK kopiere, und die erstellte POI.OVM in ShowGPS.OVM umbenenne, und
das ganze ins NCK-POI-Verzeichnis kopiere funktioniert alles, die POI's werden
angezeigt und man kann sie auch anwählen. Smile
In der Version vom Di. war dieser Fehler noch nicht.
Und das mit den Kategorieverzeichnissen kannste vergessen,
das passt schon so wie du es gemacht has Smile
Wir sind alle stolz auf dich Laughing
Gruss
Mario
Amigo1981
BeitragVerfasst: Fr 23 Nov, 2007 09:46  Titel:  (Kein Titel)
Wie er schon gesagt hat, ShowGPS ist auf NavigatoR 2.0 ausgelegt.
Und da klappt der Export ohne Fehlermeldungen und ebenso die Unterkategorien problemlos, was mit der Version vom Dienstag noch nicht möglich war.
Bei mir wird die ovm und cat direkt ins POI-Verzeichnis eingefügt
Gruß, Amsigo1981
[ Zeit: 1.6649s ][ Queries: 47 (1.0720s) ][ GZIP Ein - Debug Ein ]
