tHaHooL
Anmeldung: 21.01.2005
BeitragVerfasst: Di 13 Nov, 2007 08:39  Titel:  Beta 1.42 zum Download
Die aktuelle Beta 1.42 ist draussen.
Hier der Link: http://www.fluxmedia.net/downloads/CF142.exe
Die wichtigesten Änderungen:
* Die Visualisierungen sind komplett neu geschrieben worden, es können welche von hier verwendet werden:
http://support.xmplay.com/file.php?cat_id=6
* DVD Wiedergabe funktioniert nun auch unter Vista
* Einige Änderungen im DVD Menü
* DVD Ordner können nun direkt von der Festplatte gelesen werden
Hier die offiziellen Release Notes
Centrafuse 1.42 Release Notes
Important Notes
1. when listening to Radio or XM, voice recognition will not properly work unless you have a USB or Bluetooth microphone, this is due to buffering/recording
New Features
1. added back typing letters in list views making it jump in the list
2. fixed phonecontrol hibernation/standby issue
3. removed satellite radio from main application and into a seperate plugin
4. if password is set you must enter it to exit, shutdown, restart, hibernate, standby, or minimize the system
5. added four gestures for left, right, up, and down configurable from gestures.xml file
6. added throw scrolling to list views
7. added new search to navigation address screens, use to search large list of streets/cities/postal codes
8. added new ALL to the top of all POI lists with subcategories, can be used for example to list all gas stations with the closest at the top
9. my library auto populates current playlist in OSK when saving while playing the current playlist, makes editing quicker
10. added support in OBDII for elm323 v2.0
11. added disconnect icon for phone
12. added 200khz tuning step in radio settings
13. DVD now works in Vista
14. added support to play DVD folders from hard drive
15. added support for changing DVD audio streams
16. added support for changing DVD subtitles
Bugs Fixed
1. removed delay when first loading application caused by loading of the navigation engine
2. added extra error handling around removing files/directories
3. navigation ETR is properly displayed when trip length is over 24 hours
4. internet url in config.xml is properly read and used in application
5. application resets system shell back if license expires
6. activation is less strict to account for small hardware changes
7. invalid license is automatically removed
8. parameters are properly set when running as system shell
9. navigation address auto completion for large maps should work past the letter G
10. video is properly shown if playing when switching skins
11. video panel properly shows/hides when switching between music/picture/video playlists
12. fixed playlist limit, HD playlists are properly limited to 10
13. remove properly deletes the selected item in "my library"
14. remove works in "my library" when using single click
15. remove moves you back when deleting albums in single click
16. fixed bug in saving favorites in web browser
17. using scan button, on certain radio devices, application scans frequencies using step in radio settings
18. when using tune button in radio, you can now input only MHz, you do not have to type in Kh, ex (107.00 can be typed 107)
19. radio scanning works when you leave radio section
20. fixed bug loading old playlists with files that no longer exist
21. 15k eq setting now properly saves and reloads on restart
22. pre/wave no longer changes when you save navigation settings or restart
23. changing navigation settings no longer affects the volume
24. fixed bug with other regions not getting autocompletion working in navigation address searching
25. navigation address search auto completion does not move list if letter is not recognized, makes it not jump to random places
26. database no longer gets corrupt and added auto database backup and restore
27. fixed bug when saving a mixer preset with the same name and added dialog to verify you want to overwrite settings
28. playlist properly re-loads on restart, fixed duplicates and missing songs
29. queue in my library properly displays previous loaded playlist on restart
30. if minimized window will restore on navigation turn approach
31. fixed radio hotkey
32. eq and balance controls work with radio, and switching between media and radio
33. fixed issue with play now in my library playing entire library when not supposed too
34. improved radio buffer quality
35. when not using buffering and switching to radio it no longer changes recording device, which caused issues with phone and voice control
36. fixed navigation not saving settings such as imperial/metic, etc...
37. radio buffer properly works, issue with it not working after paused for too long has been fixed
38. mixer supports more sound devices and rear/sub is properly working
39. when using slider in mixer volume dialog no longer shows
40. navigation voice mutes when the system mutes, example incoming phone call
41. fixed issue with radio switching display to FM mode when hibernating in AM mode
42. fixed issue with navigation address search not remembering selection when hitting back
43. fixed using navigation address search with keyboard
44. my libary queue is populated correctly when using playlists
45. fixed media player current album label when listening to playlist
46. fixed issues with loading playlist, adding songs, and saving playlist agai
47. fixed email plugin issue with password not getting properly saved in some cases
48. fixed email plugin loading delay when no internet connection available
49. fixed bug with clicking top label and audio plugins, it now loads the plugin
50. fixed cd import not showing up after losing focus
51. full screen external application images fixed for new skin Aura
52. using the mouse scroll wheel on list views properly highlights items in the list view
53. double click and clicking forward works in navigation map history dialog
54. added check for Vista so DVD no longer causes error dialog, this is temporary until the new DVD is finished that works with Vista
55. Aura skin mute button displays properly in the down state
56. Aura skin connection status icon properly shows disconnected
57. unmute from navigation no longer starts music when external application has pause music flag turned on
58. volume buttons properly work when held down in video and DVD sections
59. fixed issue with closing external applications in some cases
60. improved external application OSK support with sending text to external applications
61. fixed issue with fastforward and using the buffer
[ Zeit: 1.6211s ][ Queries: 47 (1.0366s) ][ GZIP Ein - Debug Ein ]
