6i6i
Anmeldung: 05.12.2006
BeitragVerfasst: Fr 08 Jun, 2012 18:35  Titel:  ADS Radio wechselt Frequenz nicht
Hi!
Habe folgendes Problem. Mein ADS Radio funktioniert eigentlich einwandfrei. Bis auf das, dass ich die Frequenz nicht per Stationstaste wechseln kann (Tuning funktioniert).
Hier mal ein Auszug ausm ADSRadio.log:
Code:
18:02:54.2656250: Frequency   Exception occured:
System.Configuration.ConfigurationErrorsException: Root element is missing. (D:\WINDOWS\assembly\GAC_MSIL\ADSRadio\1.0.0.0__c0d5995ae45101b5\ADSRadio.dll.config) ---> System.Xml.XmlException: Root element is missing.
   at System.Xml.XmlTextReaderImpl.Throw(Exception e)
   at System.Xml.XmlTextReaderImpl.ThrowWithoutLineInfo(String res)
   at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
   at System.Xml.XmlTextReaderImpl.Read()
   at System.Xml.XmlTextReader.Read()
   at System.Configuration.XmlUtil..ctor(Stream stream, String name, Boolean readToFirstElement, ConfigurationSchemaErrors schemaErrors)
   at System.Configuration.BaseConfigurationRecord.InitConfigFromFile()
   --- End of inner exception stack trace ---
   at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
   at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors)
   at System.Configuration.Configuration..ctor(String locationSubPath, Type typeConfigHost, Object[] hostInitConfigurationParams)
   at System.Configuration.ClientConfigurationHost.OpenExeConfiguration(ConfigurationFileMap fileMap, Boolean isMachine, ConfigurationUserLevel userLevel, String exePath)
   at System.Configuration.ConfigurationManager.OpenExeConfigurationImpl(ConfigurationFileMap fileMap, Boolean isMachine, ConfigurationUserLevel userLevel, String exePath)
   at System.Configuration.ConfigurationManager.OpenExeConfiguration(String exePath)
   at ADSRadio.ADSRadioConnector.°()
   at ADSRadio.ADSRadioConnector.set_Frequency(Double value)
Den Fehler mit
Habe ich fast bei jeder Logmessage..??
Subaru_tom
Anmeldung: 22.07.2007
BeitragVerfasst: So 10 Jun, 2012 14:45  Titel:  (Kein Titel)
Also wenn ich mich richtig entsinne muß die Belegung der Stationstasten bei cPos von Hand in die radio.ini eingetragen werden. Siehe Wiki. Der Inhalt sieht dann etwa so aus:
[Presets]
1=HR 1
2=Antenne
3=Primavera
4=BR 1
5=B5 Akt.
6=HR 4
[Keys]
1=906
2=1030
3=994
4=956
5=1064
6=1016
6i6i
BeitragVerfasst: Do 21 Jun, 2012 22:25  Titel:  (Kein Titel)
Hmm das habe ich auch eingetragen.. Sad
[Options]
ComPort=e
Type=0
Scan=50
Refresh=500
AudioIn=1
Volume=50
Bass=7
Treble=7
Balance=30
Fader=60
Loudness=7
TIM=0
TMCScanTime=10
SaveMode=1
[Presets]
Last=6
1=OE 3
3=ANTENNE
5=FM4
2=KRONEHIT
4=NJOY
6=RADIO-ST
[Keys]
1=1008
3=0991
5=1017
2=1075
4=0882
6=0954
Subaru_tom
BeitragVerfasst: Fr 22 Jun, 2012 09:53  Titel:  (Kein Titel)
Ja so wie die Einträge sind, müssten die Sendernamen im Skin angezeigt werden und der Senderwechsel eigentlich funktionieren. Seltsam finde ich nur den Eintrag Comport=e, denn so würde das Radio gar nicht laufen. Du verwendest aber auch WinXP oder? Denn bei Win7 könnte es noch sein, das cPos die falsche radio.ini verwendet (VirtualStore).
6i6i
BeitragVerfasst: Fr 22 Jun, 2012 11:28  Titel:  (Kein Titel)
HI!
Ja die Sendernamen werden angezeigt. Das Radio funktioniert soweit auch komplett, nur eben der Senderwechseln nicht. Der Eintrag Comport=e passt soweit auch, da das ADS ja nicht direkt über den Comport angesprochen wird, sondern über eine DLL soweit ich das mitbekommen habe. Ich bekomme auch keinen Fehler im Error.log von Cpos, wenn ich den Sender wechseln will.
Es funktioniert einfach die setFrequency vom ADS Radio nicht. Alles andere wie gesagt funktioniert (RDS, Sendertext, Suchlauf,..).
Subaru_tom
BeitragVerfasst: Fr 22 Jun, 2012 12:50  Titel:  (Kein Titel)
Also dürfte das Problem eher bei der zusätzlichen dll liegen nicht bei cPos. Die Einträge im log deuten ja darauf hin das da irgendetwas fehlt oder defekt ist (net.framework und oder dll). Vielleicht kann dridders mehr dazu sagen.
meph
Anmeldung: 27.12.2013
BeitragVerfasst: Fr 27 Dez, 2013 14:29  Titel:  (Kein Titel)
Hallo zusammen,
gibt es zu diesem Thema Neuigkeiten? Habe genau das gleiche Problem. Allerdings funktionierte erst alles reibungslos. "Plötzlich" ging ein Senderwechsel über die gespeicherten Sender Buttons nicht mehr. Tunen geht auch bei mir noch.
Ich konnte herausfinden dass folgendes funktioniert:
-Radiosender läuft: zb. WDR2
-Senderwechsel über Button zb auf einlive (wechselt nicht, nur frequenzanzeige wechselt)
-zurück ins Hauptmenü und dann ins Multimedia (mp3)
- wieder zurück über das hauptmenü zu radio
- der sender auf den gewechselt werden sollte läuft
Irgendwas hängt da quer....hatte das in der Vergangeheit schonmal da half es das Radio AddOn neu zu installieren, würde aber eine nicht ganz so "brutale" lösung vorziehen, die das Problem an sich bekämpft und damit dauerhaft ist.
[ Zeit: 1.6733s ][ Queries: 47 (0.5414s) ][ GZIP Ein - Debug Ein ]
