Franco DJ
Anmeldung: 01.10.2005
BeitragVerfasst: Sa 01 Okt, 2005 22:26  Titel: Oooh ! Power transformer for K-301 ???
Any one know what type of power transformer is correct to operate K-301 .
1 Din
Black -->GND
Blue -->Reverse
Orange--> Remote
Red -->Accon
Green -->Park
Yellow -->+12 DC
I connect
Black and Green to 0V GND
Red, Green, Yellow to +12DC
I use power transformer In 12V (from cigarette lighter) ---> Out 12V 800 mA
Before power transformer there is fuse 3,5A but when i connect my K-301 the fuse of power transformer broken. Rolling Eyes
Anyone have K-301 what type of solution use to run K-301 ?
Thanks Cool
WolfgangPue
Anmeldung: 08.10.2004
BeitragVerfasst: So 02 Okt, 2005 08:51  Titel:  (Kein Titel)
You do not need to connect all cables, to use the k301.
Black -> GND
Yellow, Red -> +12DC
Maybe there is a short circuit if you connect the wires your way.
Greetings Wolfi
Franco DJ
BeitragVerfasst: So 02 Okt, 2005 09:58  Titel:  (Kein Titel)
oK THANKS FOR INFORMATION,
What type power supplies do you use?
I don't know the power consuption (Watt, A, V)??? Cool
WolfgangPue
BeitragVerfasst: So 02 Okt, 2005 15:33  Titel:  (Kein Titel)
I use the DC/DC Convertver (Revision 2 - Timing) from www.cartft.com for my CarPc and the K301.
But this power supply is shit, and so i orderd the carnetix CNX-P1290 DUAL.
Watt = A * V
9,6 = 0,8 * 12
The K301 needs 9 Watt, and so the power of your power supply can be a little bit to low.
By the way: For the K301 you don't need a power supply. You can connect the k301 direct to the battery.
Franco DJ
BeitragVerfasst: So 02 Okt, 2005 18:53  Titel:  (Kein Titel)
Hello,
I connect direct to 12V of battery and it run. Razz
Is necessary connect:
12 V = yellow and red
0 V = black and green
If you connect only Yellow and Green the K301 not run !!!
Wink Thanks WolfgangPue for your information Wink
horob
Anmeldung: 13.01.2005
BeitragVerfasst: Mo 03 Okt, 2005 00:12  Titel:  (Kein Titel)
Buon giorno Franco,
si parla anche italiano !
ma, avete gia computer in Italia ???? Very Happy
Roberto
Franco DJ
BeitragVerfasst: Mo 03 Okt, 2005 21:55  Titel:  (Kein Titel)
CIAO HOROB,
Conosci percaso l'Italiano ?
Question Cosa intendi con la domanda "avete gia computer in Italia". Question
[ Zeit: 0.7058s ][ Queries: 47 (0.3123s) ][ GZIP Ein - Debug Ein ]
