haifisch
Anmeldung: 22.10.2005
BeitragVerfasst: So 09 Apr, 2006 16:17  Titel:  Scriptänderung gebraucht
Servus,
hab da ein Script, welches gefundene AP's mit deren Namen nennt und ob diese verschlüsselt oder nicht sind.
Nun, da die Namensnennung teilweise ewig braucht, hätte ich gern den Teil aus dem Script rausgenommen, sodass nur open closed angesagt wird.
Folgend der meiner Meinung nach wichtige Teil, vorsichtshalber unten das ganze Script.
Danke für Hilfe.
*************** User Configurable Switches ****************
'***** Mappoint
UseMappoint = True '20040426 - True if you want to use Mappoint - this overrides
' DropCrumbs and TrackVehicle
place = "camino de valhondo O barajas, 28042 Madrid, Spain" 'Enter your starting location (street,#, city, country)
zoomToStartLoc = True ' True if you want MapPoint to zoom to start location entered in 'place' above
DropCrumbs = True ' True to put black dots everywhere we go, False otherwise
TrackVehicle = True ' True to follow your location while scanning
'***** Speech
UseSpeech = True ' Speak names of networks in view
AddWEP = True '20040429b - True if you want voice to add WEP status "is Open" or "is Closed" to the SSID
strNoWep = " is Open" ' Set to what you want added to SSID for NonWEP
strWEP = " is Closed" ' Set to what you want added to SSID for WEP
VoiceNum = Empty ' 20040504 set this to the number of the voice you want to use - Setting to Empty will use the default voice
'***** Sounds
UseAudio = False ' Traditional script audio - if you are using speech this will only trigger if there are no
' new ssids to say
UseSignalStr = False '20040426 - True if you want the varying signal strength sounds - if you are using speech
'this will only trigger if there are no new ssids to say, and UseAudio = True
'*********************End of switches***********************
'Version 00:19 20040511
'20040426 Marks changes made to use speech, when you are not lucky enough to have
' Mappoint. Also adds ability to turn off signal strength playing - TPEER
'20040429a Marks changes made to allow setting of voice - find \HKEY_LOCAL_MACHINE\SOFTWARE\
' Microsoft\Speech\Voices\Tokens - that should give you a list of voices you can set
' it starts at 0, not 1. Change the line "Set TTS.voice = TTS.getvoices().item(X)" where X
' equals the number of the voice you want - TPEER
'20040429b Marks changes made to store the WEP status with the SSID, so the 'Stumbler Lady' will
' add "is Open" or "is Closed" - TPEER
' Start of by Laidback 030504
' Start of by Laidback - Start of Changes made by Laidback
' End of by Laidback - End of Changes made by Laidback
' Code thanks to TrackNS & rogerRabbit!
' End of by Laidback 030504
'20040504 Marks change to allow override of default voice by this script
' Also set VoiceNum to the number of the voice you want to use
' Will say the name of the voice IF you override the default - TPEER
'20040506 Changes to Voice stuff. If VoiceNum = Empty, the default voice will used
' Modified the hello world message to be the name of the voice used
' organized the user changeable switches/variables a little
' Changed all mappoint stuff to not be checked unless UseMAppoint = True - TPEER
'20040509 Version 00:18 - Removed everything to do with zoomcontrol.txt! - Laidback
'20040511 Version 00:19 - Added message boxes if unable to initialize voice or mappoint
' Added variable for what to add to WEP and NOWEP SSIDs
' Fixed bug with UseSpeech - TPEER
Dim ActiveMap
Dim LastLocation
Dim MapPointApp
Dim HistoryPushpins
Dim MotionPushpins
Dim WLANPushpins
Dim Vehicle
Dim Initialized
Dim BSSID_Dictionary, Spoken_BSSIDs, New_SSIDs
Dim IsScanning
Dim HadGPSData
Dim LastLatitude, LastLongitude, LastAltitude
Dim DropCrumbs, TrackVehicle, UseSpeech, UseAudio
Dim LastHighlighted
Dim UseMappoint ' 20040426
Dim UseSignalStr ' 20040426
Dim AddWEP ' 20040429b
Dim strNoWEP '20040511
Dim strWEP '20040511
Dim VoiceNum '20040504
Dim CL, nameDir
nameScript = "ns04mappoint00:19"
' end of by Laidback 030504
' Start of by Laidback 050504
Dim place
Dim zoomToStartLoc
' End of by Laidback 050504
'*************** User Configurable Switches ****************
'***** Mappoint
'***** Speech
strNoWep = " offen" ' Set to what you want added to SSID for NonWEP
strWEP = " zu" ' Set to what you want added to SSID for WEP
'***** Sounds
' new ssids to say
If UseMappoint Then '20040426
AddItemContextMenu "HighlightOnMap", "Highlight on map"
End If '20040426
Set LastHighlighted = Nothing
Set WLANPushpins = Nothing
Dim TTS
On Error Resume Next ' 20040511
If UseSpeech Then
Set TTS = CreateObject("Sapi.SpVoice")
If Err <> 0 then ' 20040511
UseSpeech = False ' 20040511
MsgBox "Unable to wake up Stumbler Lady", 16, nameScript '20040511
End If ' 20040511
End If
If UseSpeech then ' 20040511
If TTS Is Nothing Then
UseSpeech = False
else ' 20040429a
Set TTS.voice = TTS.getvoices().item(VoiceNum) ' 20040429a
End If
End If
If UseSpeech Then
TTS.Speak TTS.getvoices().item(VoiceNum).getdescription ' 20040505
'TTS.Speak "Hello Ian!" ' commented out 20040505
Set Spoken_BSSIDs = CreateObject("Scripting.Dictionary")
Set New_SSIDs = CreateObject("Scripting.Dictionary")
End If
Initialize
Sub Initialize()
HadGPSData = False
Set BSSID_Dictionary = CreateObject("Scripting.Dictionary")
' Try to get a handle to an existing instance of MapPoint
Set MapPointApp = GetObject(, "MapPoint.Application")
' No instance found, create one.
If Err <> 0 Then
Err.Clear
Set MapPointApp = CreateObject("MapPoint.Application")
If Err = 0 then ' 20040505
MapPointApp.Visible = True
MapPointApp.UserControl = False
MapPointApp.Activate
else '20040505
Msgbox "Unable to initialize Mappoint", 16, nameScript '20040511
Err.Clear ' 20040505
UseMappoint = False ' 20040505
place = "" ' 20040505
zoomToStartLoc = False ' 20040505
DropCrumbs = False ' 20040505
TrackVehicle = False ' 20040505
End If ' 20040505
End If
End If ' 20040505
If UseMappoint Then '20040505
Set ActiveMap = MapPointApp.ActiveMap
Dim StartLoc
Set StartLoc = ActiveMap.FindResults(place)(1) ' Middle of, uh, somewhere
If DropCrumbs Then
Set HistoryPushpins = ActiveMap.Datasets.AddPushpinSet("Location History")
If Err <> 0 Then
Err.Clear
Set HistoryPushpins = ActiveMap.Datasets("Location History")
End If
End If
Set WLANPushpins = ActiveMap.Datasets.AddPushpinSet("Wireless LAN data")
If Err <> 0 Then
Err.Clear
Set WLANPushpins = ActiveMap.Datasets("Wireless LAN data")
End If
If TrackVehicle Then
Set MotionPushpins = ActiveMap.Datasets.AddPushpinSet("Last Location")
If Err <> 0 Then
Err.Clear
Set MotionPushpins = ActiveMap.Datasets("Last Location")
End If
Set Vehicle = MotionPushpins("Last Location")
If Err <> 0 Then
Err.Clear
Set Vehicle = FindOrAddPushpin(StartLoc, "Last Location", False)
End If
Vehicle.Symbol = 82 ' red car, just like the stumblemobile Smile
Vehicle.Highlight = True
Vehicle.MoveTo (MotionPushpins)
if zoomToStartLoc = True then
MotionPushpins.ZoomTo
End if
End If
End If '20040426
Initialized = True
IsScanning = True
End Sub
Function SSIDIcon(SSID)
Dim i, s
s = 0
For i = 1 To Len(SSID)
s = s + Asc(Mid(SSID, i, 1))
Next
SSIDIcon = 17 + (s Mod 47)
End Function
Sub HighlightOnMap(BSSID, SSID)
If Not LastHighlighted Is Nothing Then
LastHighlighted.Highlight = False
LastHighlighted.BalloonState = 0
End If
If BSSID_Dictionary.Exists(BSSID) Then
Set LastHighlighted = BSSID_Dictionary.Item(BSSID)
LastHighlighted.Highlight = True
LastHighlighted.BalloonState = 2
LastHighlighted.GoTo
End If
End Sub
Function FindOrAddPushpin(Loc, Title, InDict)
Dim pp
Set pp = Nothing
Set pp = ActiveMap.AddPushpin(Loc, Title)
If pp Is Nothing Then Set pp = ActiveMap.FindPushpin(Title)
If InDict Then Set BSSID_Dictionary.Item(Title) = pp
Set FindOrAddPushpin = pp
End Function
Sub OnGPSPosition(Lat, Lon, Alt)
' Lat : double : Latitude, degrees east
' Lon : double : Longitude, degrees north
' Alt : double : Altitude above sea level, meters
If Not Initialized Then
Initialize
End If
on error resume next
If HadGPSData Then
' If we haven't moved, do nothing.
If LastLatitude = Lat And LastLongitude = Lon And LastAltitude = Alt Then Exit Sub
End If
LastLatitude = Lat
LastLongitude = Lon
LastAltitude = Alt
Set LastLocation = ActiveMap.GetLocation(Lat, Lon, Alt)
If DropCrumbs Then
Dim Crumb
Set Crumb = FindOrAddPushpin(LastLocation, Lat & " " & Lon & " " & Alt, False)
Crumb.Symbol = 16 ' Small black circle
Crumb.MoveTo (HistoryPushpins)
End If
' Move the visual indicator to the new location.
Set Vehicle.Location = LastLocation
If IsScanning Or Not HadGPSData Then
' If scanning or first position, center the map on the new location
UpdateCurrentLocation Lat, Lon
End If
End If
End If '20040426
HadGPSData = True
End Sub
' Called when user requests that scanning start, or when scanning is started automatically.
Sub OnEnableScan()
If Not HadGPSData Then Exit Sub ' Discard while no GPS
Initialize
End If
IsScanning = True
End Sub
' Called when user requests that scanning stop.
Sub OnDisableScan()
If WLANPushpins Is Nothing Then
' Blah
Else
WLANPushpins.ZoomTo
End If '20040426
End If
IsScanning = False
End Sub
Sub OnScanResult(SSID, BSSID, CapFlags, Signal, Noise, LastSeen)
' SSID : String : SSID (Network name)
' BSSID : String : BSSID (MAC address)
' CapFlags : Integer : 802.11 capability flags
' Signal : Integer : signal level (dBm)
' Noise : Integer : noise level(dBm)
' LastSeen : Time
Dim ComboSSID '20040429
' If UseSpeech And Not Spoken_BSSIDs.Exists(BSSID) Then 20040511
If UseSpeech Then '20040511
If Not Spoken_BSSIDs.Exists(BSSID) Then '20040511
' TTS.Speak SSID, SVSFlagsAsync
' New_SSIDs.Item(SSID) = 1 ' 20040429b
ComboSSID = SSID ' 20040429
If AddWEP then '20040429b
If ((CapFlags / 16) Mod 2) = 1 Then '20040429b
ComboSSID = SSID & strWEP '20040429b
Else '20040429b
ComboSSID = SSID & strNoWEP '20040429b
End If ' 20040429b
End If '20040429b
New_SSIDs.Item(ComboSSID) = 1 ' 20040429b
Spoken_BSSIDs.Item(BSSID) = LastSeen ' Could check and see if it's been a long time, play again
End If
End If
End Sub
' Called to indicate that NetStumbler has changed its location information
' for a BSSID. The new location may not necessarily be the place where you
' are right now.
' History: New in 0.4.
Sub OnPositionChange(SSID, BSSID, CapFlags, MaxSNR, Lat, Lon, Alt, FixType)
' MaxSNR: Integer : highest seen signal-to-noise ratio (dB) that had a position fix associated with it
' Lat : Double : Newly calculated latitude, degrees
' Lon : Double : Newly calculated longitude, degrees
' Alt : Double : Newly calculated altitude (currently not calculated)
' FixType : Integer : Reserved for future use.
' To get here, start with no script, start scan, then enable script
Initialize
IsScanning = True
End If
Dim foundBSS, newLocation
Set newLocation = ActiveMap.GetLocation(Lat, Lon, Alt)
Set foundBSS = BSSID_Dictionary.Item(BSSID)
Set foundBSS.Location = newLocation
Else
Set foundBSS = FindOrAddPushpin(newLocation, BSSID, True)
foundBSS.MoveTo (WLANPushpins)
foundBSS.Symbol = SSIDIcon(SSID)
End If
Dim Flags
Flags = ""
If (CapFlags Mod 2) = 1 Then Flags = Flags & "ESS "
If ((CapFlags / 2) Mod 2) = 1 Then Flags = Flags & "IBSS "
If ((CapFlags / 16) Mod 2) = 1 Then Flags = Flags & "WEP "
foundBSS.Note = "SSID: " & SSID & vbCrLf & _
"BSSID: " & BSSID & vbCrLf & _
"CapFlags: " & Flags & " (" & Hex(CapFlags) & ")" & _
"SNR: " & MaxSNR
Set newLocation = Nothing
End If '20040426
End Sub
' Called when a scan cycle has completed (typically right before a new one starts).
Sub OnScanComplete(FoundNew, SeenBefore, LostContact, BestSNR)
' FoundNew : Integer : Count of new BSSIDs
' SeenBefore : Integer : Count of not-new BSSIDs
' LostContact : Integer : Count of BSSIDs missed since last scan
' BestSNR : Integer : SNR of strongest signal (dBm)
'If UseSpeech And (New_SSIDs.Count > 0) Then 20040511
If (New_SSIDs.Count > 0) Then '20040511
Dim n, a
n = New_SSIDs.Count
a = New_SSIDs.Keys
For i = 0 To n - 1
TTS.Speak a(i), SVSFlagsAsync
Next
New_SSIDs.RemoveAll
ElseIf UseAudio Then
If FoundNew > 0 Then
PlaySound "ns-aos-new.WAV"
ElseIf LostContact > 0 Then
PlaySound "ns-los.WAV"
ElseIf SeenBefore > 0 Then
If UseSignalStr Then '20040426
' Still seeing some
If BestSNR >= 60 Then
PlaySound "ns-signal-6.WAV"
ElseIf BestSNR >= 50 Then
PlaySound "ns-signal-5.WAV"
ElseIf BestSNR >= 40 Then
PlaySound "ns-signal-4.WAV"
ElseIf BestSNR >= 30 Then
PlaySound "ns-signal-3.WAV"
ElseIf BestSNR >= 20 Then
PlaySound "ns-signal-2.WAV"
ElseIf BestSNR >= 10 Then
PlaySound "ns-signal-1.WAV"
Else
PlaySound "ns-signal-0.WAV"
End If
End If '20040426
Else
' Nothing seen
' PlaySound "ns-tick.WAV"
End If
End If '20040511
End If
End Sub
Sub UpdateCurrentLocation (thisLat, thisLon)
lastLatTrack = FormatMP(thisLat)
lastLonTrack = FormatMP(thisLon)
Set CL = ActiveMap.GetLocation(FormatMP(thisLat), FormatMP(thisLon))
If Err.Number <> 0 Then Exit Sub
CL.GoTo()
End Sub
Function FormatMP (thisCoord)
FormatMP = FormatNumber(thisCoord, 5)
End Function
paul_mönkeberg
Anmeldung: 23.02.2006
BeitragVerfasst: Mo 10 Apr, 2006 15:03  Titel:  (Kein Titel)
das ding wäre ne coole sache wenns schnell arbeitet. nett wäre auch ein kleiner sound wenn er einen offenen ap gefunden hat.
Paulo
haifisch
BeitragVerfasst: Mo 10 Apr, 2006 18:28  Titel:  (Kein Titel)
Machts ja. >ssid bla bla bla is open> Auch in Map Point wird die Strecke und die AP's aufgezeichnet.
Nur gib mal in der Testzeile der Sprachausgabe (Systemsteuerung folgendes ein ///\\\7865432 dann bist schon nen km weiter.
paul_mönkeberg
BeitragVerfasst: Mi 12 Apr, 2006 12:07  Titel:  (Kein Titel)
besitzt denn netstumbler nicht die Funktion der benachrichtigung, zu singnalisieren, wenn ein AP offen ist? Dafür ist doch netstumbler da oder? Dann bräuchte man das skript ja nicht mehr oder? Auch wenn ich die idee des Skripts verdammt cool finde...
haifisch
BeitragVerfasst: Mi 12 Apr, 2006 16:02  Titel:  (Kein Titel)
Schon, aber lieber hör ich asd open fde closed usw als ping pong plang bim.
Da werd ich ganz kirre.
paul_mönkeberg
BeitragVerfasst: Do 13 Apr, 2006 11:32  Titel:  (Kein Titel)
ich denke ich muss mal netstumbler ausprobieren, soll doch eigentlich ganz gut sein. somit sollte es doch auch nach deinen wünschen konfigurierbar sein. aber ma schaun ob du das Projekt mit deiner Lösung auch hinbekommst, wäre ja noch um einiges schlankere lösung.
paul_mönkeberg
BeitragVerfasst: Di 02 Mai, 2006 11:22  Titel:  (Kein Titel)
Gibbes in deinem Projekt eigentlich schon neuigkeiten???Bist du schon weiter???
Gruß Paulo
[ Zeit: 1.7069s ][ Queries: 48 (1.0025s) ][ GZIP Ein - Debug Ein ]
