NumberOne
Anmeldung: 13.07.2004
BeitragVerfasst: So 31 Okt, 2004 12:14  Titel: Oh Ja ! Fernsteuerung des PCs. Bin am Verzweifeln!!!!!!!
Ich hab ein Siemens S55
Hab gerade versucht laut dieser Anleitung http://zoran-horvat.de/private/CarPC/default.htm die PhoneCtl.Config.xml Datei anzupassen. Nachdem ich <keys> reingenommen hab, kommt immer folgende Fehlermeldung: "PhoneCtl.Config.xml not found".
Was mache ich jetzt falsch???
hier ist meine PhoneCtl.Config.xml :
Code:
<?xml version="1.0" encoding="utf-8"?>
<PhoneControl>
  <!--===== Section which defines the primary settings for Communication, Design and Languange =====-->
  <UseCommConfig>Siemens</UseCommConfig>
  <UseDesign>Designs\PhoneCtl.Design1.xml</UseDesign>
  <UseLanguage>Deutsch</UseLanguage>
  <!--===== Section containing the communication settings for different devices =====-->
  <Communication id="SonyEricsson">
    <Port />
    <Setting>38400,N,8,1</Setting>
    <Vendor>Siemens</Vendor>
    <PhoneBookLocation id="1" timeout="90" name="Tel" static="True" startup="True" shortcut="True">ME</PhoneBookLocation>
    <PhoneBookLocation id="2" timeout="90" name="SIM" static="True" shortcut="True">SM</PhoneBookLocation>
    <PhoneBookLocation id="3" timeout="30" name="RC" static="False" shortcut="True" sorted="False" showDate="True">RC</PhoneBookLocation>
    <PhoneBookLocation id="4" timeout="30" name="MC" static="False" shortcut="True" sorted="False" showDate="True">MC</PhoneBookLocation>
    <PhoneBookLocation id="5" timeout="30" name="DC" static="False" shortcut="True" sorted="False" showDate="True">DC</PhoneBookLocation>
    <UseCharset>8859-1</UseCharset>
    <UseClip>True</UseClip>
    <UseCPAS>True</UseCPAS>
    <UseCLCC>False</UseCLCC>
    <UseCNMI mode="2,1">True</UseCNMI>
    <AdditionalInit>*EAPM=3</AdditionalInit>
    <AdditionalDeinit>*EAPM=0;</AdditionalDeinit>
  </Communication>
  <UseKeyMap locked="False">...</UseKeyMap>
  <Communication id="Siemens">
    <Port>5</Port>
    <Setting>19200,N,8,1</Setting>
    <PhoneBookLocation timeout="60">SM</PhoneBookLocation>
    <UseCharset>GSM</UseCharset>
    <UseCNMI mode="1,1">True</UseCNMI>
    <AdditionalInit>+CMER=3,2</AdditionalInit>
<Keys>
   <Key id="Key_0">0</Key>
   <Key id="Key_1">1</Key>
   <Key id="Key_2">2</Key>
   <Key id="Key_3">3</Key>
   <Key id="Key_4">4</Key>
   <Key id="Key_5">5</Key>
   <Key id="Key_6">6</Key>
   <Key id="Key_7">7</Key>
   <Key id="Key_8">8</Key>
   <Key id="Key_9">9</Key>
   <Key id="Key_Star">*</Key>
   <Key id="Key_Hash">#</Key>
   <Key id="Key_VolUp">+</Key>
   <Key id="Key_VolDown">-</Key>
   <Key id="Key_Up">^</Key>
   <Key id="Key_Down">:V</Key>
   <Key id="Key_Left">&lt</Key>
   <Key id="Key_Right">&gt</Key>
   <Key id="Key_Enter">]</Key>
   <Key id="Key_Back">[</Key>
   <Key id="Key_Clear">S</Key>
   <Key id="Key_FK1">[</Key>
   <Key id="Key_FK2">M</Key>
   <Key id="Key_FK3">]</Key>
   <Key id="Key_FK4">:T</Key>
</Keys>
  </Communication>
  <Communication id="Nokia">
    <Port />
    <Vendor>Nokia</Vendor>
    <PhoneBookLocation timeout="60">ME</PhoneBookLocation>
    <UseClip mode="1">True</UseClip>
    <UseCRC mode="1">True</UseCRC>
    <Keypad quote="True" terminate="False">+VTS</Keypad>
  </Communication>
  <Communication id="Motorola">
    <Port />
    <Vendor>Motorola</Vendor>
    <UseCLCC>True</UseCLCC>
    <UseCNMI mode="3,1">True</UseCNMI>
    <Keypad quote="True" terminate="False">-MVTS</Keypad>
  </Communication>
  <Communication id="LG (CDMA)">
    <Port />
    <Vendor>LG</Vendor>
    <Dial quote="True" terminate="True">+CDV</Dial>
    <Hangup>+CHV</Hangup>
  </Communication>
  <Communication id="Falcom A1">
    <Port />
    <Setting>9600,N,8,1</Setting>
    <Vendor>Falcom</Vendor>
    <UseClip>False</UseClip>
    <UsePIN pin="">True</UsePIN>
  </Communication>
  <!-- ===== Section containing the with main settings =====-->
  <MainWindow>
    <Window>0,0,800,600</Window>
    <WindowToSwitchTo />
    <SpeechEnabled>True</SpeechEnabled>
    <LogEnabled>True</LogEnabled>
    <MediaPlayer>WMPlayer</MediaPlayer>
    <MuteAnalogMic>True</MuteAnalogMic>
    <MainVolumeOnCall restoreVolume="True">20%</MainVolumeOnCall>
    <StartupMode>Normal</StartupMode>
    <UseOSK executable="osk.exe">True</UseOSK>
    <AutoHideTimeout>0</AutoHideTimeout>
    <BuildAbsolutePath>True</BuildAbsolutePath>
    <Standalone>False</Standalone>
    <Ringtone />
    <SMStone />
    <UseTaskbar>False</UseTaskbar>
  </MainWindow>
  <!--===== Section with text used within the application =====-->
  <Texts id="Deutsch">
    <Text id="LoadingMsg">Das Telefonbuch des Mobiltelefons wird gelesen...</Text>
    <Text id="CallFrom">Anruf von:</Text>
    <Text id="SMSSendOK">SMS wurde versendet!</Text>
    <Text id="SMSSendError">Fehler bei SMS versand!</Text>
    <Text id="SMSFrom">SMS von:</Text>
    <Text id="SMS">SMS</Text>
    <Text id="OKText">Ok</Text>
    <Text id="CancelText">Abbrechen</Text>
    <Text id="DialManual">Manuelle Wahl</Text>
    <Text id="Dialing">Wähle Nummer:</Text>
    <Text id="CaptionMobile">Mobil</Text>
    <Text id="CaptionWork">Firma</Text>
    <Text id="CaptionHome">Privat</Text>
    <Text id="CaptionFax">Fax</Text>
    <Text id="CaptionOther">Weitere</Text>
    <Text id="Unknown">Unbekannt</Text>
    <Text id="Vendor">Hersteller:</Text>
    <Text id="PortNo">Ser. Port:</Text>
    <Text id="Config">Einstellungen:</Text>
    <Text id="Language">Sprache:</Text>
  </Texts>
  <Texts id="English">
    <Text id="LoadingMsg">Reading your mobile phonebook</Text>
    <Text id="CallFrom">Call from:</Text>
    <Text id="SMSSendOK">SMS has been sent!</Text>
    <Text id="SMSSendError">Error occured during SMS sending!</Text>
    <Text id="SMSFrom">SMS from</Text>
    <Text id="OKText">OK</Text>
    <Text id="CancelText">Cancel</Text>
    <Text id="DialManual">Dial manually</Text>
    <Text id="Dialing">Dialing number:</Text>
    <Text id="CaptionMobile">Mobile</Text>
    <Text id="CaptionWork">Work</Text>
    <Text id="CaptionHome">Home</Text>
    <Text id="CaptionOther">Other</Text>
    <Text id="Unknown">Unknown</Text>
    <Text id="Config">Settings:</Text>
    <Text id="Vendor">Vendor:</Text>
    <Text id="PortNo">Ser. port:</Text>
    <Text id="Language">Language:</Text>
  </Texts>
  <Texts id="Português">
    <Text id="LoadingMsg">A Carregar Mensagens...</Text>
    <Text id="CallFrom">Chamada de </Text>
    <Text id="SMSSendOK">Mensagem enviada!</Text>
    <Text id="SMSSendError">Envio Mensagem falhou!</Text>
    <Text id="SMSFrom">Mensagem de </Text>
    <Text id="SMS">Mensagem</Text>
    <Text id="CancelText">Cancelar</Text>
    <Text id="DialManual">Marcar</Text>
    <Text id="Dialing">A marcar </Text>
    <Text id="CaptionMobile">Telemovel</Text>
    <Text id="CaptionWork">Empresa</Text>
    <Text id="CaptionHome">Casa</Text>
    <Text id="CaptionOther">Outro</Text>
    <Text id="Unknown">Desconhecido</Text>
    <Text id="Vendor">Fabricante:</Text>
    <Text id="PortNo">P. Série:</Text>
    <Text id="Config">Configurar:</Text>
    <Text id="Language">Idioma:</Text>
  </Texts>
  <Texts id="Italiano">
    <Text id="LoadingMsg">Rubrica in caricamento..</Text>
    <Text id="CallFrom">Chiamata da</Text>
    <Text id="SMSSendOK">il tuo SMS è stato inviato!</Text>
    <Text id="SMSSendError">Errore durante l'invio SMS!</Text>
    <Text id="SMSFrom">SMS da</Text>
    <Text id="CancelText">Cancella</Text>
    <Text id="DialManual">Componi</Text>
    <Text id="Dialing">chiamata al n:</Text>
    <Text id="CaptionMobile">Cell</Text>
    <Text id="CaptionWork">Lavoro</Text>
    <Text id="CaptionOther">Altro</Text>
    <Text id="Unknown">Sconosciuto</Text>
    <Text id="Config">impostazioni:</Text>
    <Text id="Vendor">Marca:</Text>
    <Text id="PortNo">porta:</Text>
    <Text id="Language">Lingua:</Text>
  </Texts>
  <Texts id="Nederlands">
    <Text id="LoadingMsg">Telefoonnummers worden ingelezen</Text>
    <Text id="CallFrom">U wordt gebeld door:</Text>
    <Text id="SMSSendOK">SMS is verstuurd!</Text>
    <Text id="SMSSendError">Fout bij het versturen van SMS!</Text>
    <Text id="SMSFrom">SMS van</Text>
    <Text id="CancelText">Annuleer</Text>
    <Text id="DialManual">Handmatig kiezen</Text>
    <Text id="Dialing">Belt:</Text>
    <Text id="CaptionMobile">Mobiel</Text>
    <Text id="CaptionWork">Werk</Text>
    <Text id="CaptionHome">Thuis</Text>
    <Text id="CaptionOther">Anders</Text>
    <Text id="Unknown">Onbekend</Text>
    <Text id="Config">Instellingen:</Text>
    <Text id="Vendor">Leverancier:</Text>
    <Text id="Language">Taal:</Text>
  </Texts>
  <Texts id="Français">
    <Text id="LoadingMsg">Chargement des messages</Text>
    <Text id="CallFrom">Appel de :</Text>
    <Text id="SMSSendOK">SMS a été envoyé !</Text>
    <Text id="SMSSendError">L'erreur s'est produite pendant l'envoi de SMS !</Text>
    <Text id="SMSFrom">SMS de</Text>
    <Text id="CancelText">Annulation</Text>
    <Text id="DialManual">Cadran manuel</Text>
    <Text id="Dialing">Numero de telephone:</Text>
    <Text id="CaptionWork">Travail</Text>
    <Text id="CaptionHome">À la maison</Text>
    <Text id="CaptionOther">Autre</Text>
    <Text id="Unknown">Inconnu</Text>
    <Text id="Vendor">Fournisseur:</Text>
    <Text id="Language">Langue:</Text>
  </Texts>
  <Texts id="Dansk">
    <Text id="LoadingMsg">Læser din Telefonbog</Text>
    <Text id="CallFrom">Opkald fra:</Text>
    <Text id="SMSSendOK">SMS sendt!</Text>
    <Text id="SMSSendError">Fejl ved SMS afsendelse!</Text>
    <Text id="SMSFrom">SMS fra</Text>
    <Text id="CancelText">Annuller</Text>
    <Text id="DialManual">Kald op manuelt</Text>
    <Text id="Dialing">Ringer til:</Text>
    <Text id="CaptionWork">Arbejde</Text>
    <Text id="CaptionHome">Hjem</Text>
    <Text id="CaptionOther">Andet</Text>
    <Text id="Unknown">Ukendt</Text>
    <Text id="Config">Indstillinger:</Text>
    <Text id="Vendor">Udbyder:</Text>
    <Text id="Language">Sprog:</Text>
  </Texts>
  <Texts id="Polski">
    <Text id="LoadingMsg">Ksiazka telefoniczna telefonu komorkowego jest wczytywana...</Text>
    <Text id="CallFrom">Telefon od:</Text>
    <Text id="SMSSendOK">Wiadomosc SMS zostala wyslana!</Text>
    <Text id="SMSSendError">Blad podczas wysylania wiadomosci SMS!</Text>
    <Text id="SMSFrom">Wiadomosc SMS od:</Text>
    <Text id="SMS">Wiadomosc SMS</Text>
    <Text id="CancelText">Cofnij</Text>
    <Text id="DialManual">Wybor manualny</Text>
    <Text id="Dialing">Wybierz numer:</Text>
    <Text id="CaptionMobile">Komorka</Text>
    <Text id="CaptionHome">Prywatny</Text>
    <Text id="CaptionOther">Inne</Text>
    <Text id="Unknown">nieznany</Text>
    <Text id="Vendor">Producent:</Text>
    <Text id="PortNo">Port szeregowy:</Text>
    <Text id="Config">Ustawienia:</Text>
    <Text id="Language">Jezyk:</Text>
  </Texts>
  <Texts id="Türkçe">
    <Text id="LoadingMsg">Telefon Rehberiniz Okunuyor</Text>
    <Text id="CallFrom">Arayan:</Text>
    <Text id="SMSSendOK">Mesaj gönderildi!</Text>
    <Text id="SMSSendError">Mesaj gönderilemedi!</Text>
    <Text id="SMSFrom">Mesaj gönderen</Text>
    <Text id="SMS">Mesaj</Text>
    <Text id="OKText">Tamam</Text>
    <Text id="CancelText">Iptal</Text>
    <Text id="DialManual">Elle Ara</Text>
    <Text id="Dialing">Araniyor:</Text>
    <Text id="CaptionWork">Is</Text>
    <Text id="CaptionHome">Ev</Text>
    <Text id="CaptionOther">Diger</Text>
    <Text id="Unknown">Bilinmeyen</Text>
    <Text id="Config">Ayarlar:</Text>
    <Text id="Vendor">Marka:</Text>
    <Text id="Language">Dil:</Text>
  </Texts>
  <Texts id="Norsk">
    <Text id="LoadingMsg">Leser telefonlista di...</Text>
    <Text id="CallFrom">Samtale fra:</Text>
    <Text id="SMSSendOK">SMS er sendt!</Text>
    <Text id="SMSSendError">Feil ved SMS sending!</Text>
    <Text id="SMSFrom">SMS fra:</Text>
    <Text id="CancelText">Avbryt</Text>
    <Text id="DialManual">Slå nummer</Text>
    <Text id="Dialing">Ringer nummer:</Text>
    <Text id="CaptionWork">Jobb</Text>
    <Text id="CaptionOther">Annet</Text>
    <Text id="Unknown">Ukjent</Text>
    <Text id="Vendor">Merke:</Text>
    <Text id="Config">Instillinger:</Text>
    <Text id="Language">Språk:</Text>
  </Texts>
  <Texts id="????????">
    <Text id="LoadingMsg">??????s? t?? t??. ?ata?????...</Text>
    <Text id="CallFrom">???s? p???:</Text>
    <Text id="SMSSendOK">?? ????µa SMS ??e? pa?ad??e?!</Text>
    <Text id="SMSSendError">?a???s??st??e sf??µa ?at? t?? ap?st??? t?? SMS!</Text>
    <Text id="SMSFrom">????µa SMS p???</Text>
    <Text id="CancelText">?????s?</Text>
    <Text id="DialManual">???s?</Text>
    <Text id="Dialing">????µ?? ???s??:</Text>
    <Text id="CaptionMobile">????t?</Text>
    <Text id="CaptionWork">???as?a</Text>
    <Text id="CaptionHome">????a</Text>
    <Text id="CaptionOther">???p?</Text>
    <Text id="Unknown">????st?</Text>
    <Text id="Config">???µ?se??:</Text>
    <Text id="Vendor">???µ??e?t??:</Text>
    <Text id="PortNo">Se???a?? ???a:</Text>
    <Text id="Language">G??ssa:</Text>
  </Texts>
  <Texts id="Svenska">
    <Text id="LoadingMsg">Läser mobilens adressbok</Text>
    <Text id="CallFrom">Samtal från:</Text>
    <Text id="SMSSendOK">SMS har sänds!</Text>
    <Text id="SMSSendError">Fel inträffade när SMS sändes!</Text>
    <Text id="SMSFrom">SMS från</Text>
    <Text id="DialManual">Manuell uppringning</Text>
    <Text id="CaptionWork">Arbete</Text>
    <Text id="CaptionHome">Hem</Text>
    <Text id="CaptionOther">Övrigt</Text>
    <Text id="Unknown">Okänd</Text>
    <Text id="Config">Inställningar:</Text>
    <Text id="Vendor">Tillverkare:</Text>
  </Texts>
  <Texts id="Español">
    <Text id="LoadingMsg">Leyendo la agenda del teléfono</Text>
    <Text id="CallFrom">Llamada de:</Text>
    <Text id="SMSSendOK">¡SMS enviado!</Text>
    <Text id="SMSSendError">¡Envío de SMS fallido!</Text>
    <Text id="Dialing">Marcando número:</Text>
    <Text id="CaptionMobile">Móvil</Text>
    <Text id="CaptionWork">Trabajo</Text>
    <Text id="CaptionOther">Otro</Text>
    <Text id="Unknown">Desconocido</Text>
    <Text id="Config">Configuración:</Text>
    <Text id="PortNo">Puerto:</Text>
  </Texts>
  <Texts id="Chinese">
    <Text id="LoadingMsg">???????</Text>
    <Text id="CallFrom">????:</Text>
    <Text id="SMSSendOK">?????</Text>
    <Text id="SMSSendError">??????</Text>
    <Text id="SMSFrom">????</Text>
    <Text id="SMS">??</Text>
    <Text id="CancelText">??</Text>
    <Text id="DialManual">????</Text>
    <Text id="Dialing">????</Text>
    <Text id="CaptionMobile">??</Text>
    <Text id="CaptionWork">???</Text>
    <Text id="CaptionHome">??</Text>
    <Text id="CaptionFax">??</Text>
    <Text id="CaptionOther">??</Text>
    <Text id="Unknown">??</Text>
  </Texts>
</PhoneControl>
Suicider
Anmeldung: 20.01.2004
BeitragVerfasst: So 31 Okt, 2004 14:20  Titel:  (Kein Titel)
hab den selben fehler, scheint aber keinen zu interessieren
c!rYx
Anmeldung: 11.09.2004
BeitragVerfasst: So 31 Okt, 2004 17:53  Titel:  (Kein Titel)
habt ihr schonmal zorro eine mail geschrieben ? Weil er ja nichtmehr support gibt in diesem forum...
Suicider
BeitragVerfasst: So 31 Okt, 2004 17:58  Titel:  (Kein Titel)
nein, da ich dachte, dass er immer noch support übers forum gibt
c!rYx
BeitragVerfasst: So 31 Okt, 2004 19:26  Titel:  (Kein Titel)
das ist nichtmehr so ganz der fall siehe: http://car-pc.info/phpBB2/viewtopic.php?t=2305
Suicider
BeitragVerfasst: Mo 01 Nov, 2004 11:56  Titel:  (Kein Titel)
hab ihn nun angeschrieben und warte mal auf die antwort
Suicider
BeitragVerfasst: Mo 01 Nov, 2004 19:15  Titel:  (Kein Titel)
also mit meiner keymap geht es nun! Hier der code:
Code:
<PhoneControl>
   <UseCommConfig>SonyEricsson</UseCommConfig>
   <UseDesign>Designs\PhoneCtl.Modern.xml</UseDesign>
   <UseKeyMap locked="False">KeyMaps\WMP9.KeyMap.xml</UseKeyMap>
      <Port>6</Port>
      <Vendor>SonyEricsson</Vendor>
      <PhoneBookLocation id="4" timeout="30" name="DC" static="False" shortcut="True" sorted="False" showDate="True">DC</PhoneBookLocation>
      <PhoneBookLocation id="5" timeout="30" name="MC" static="False" shortcut="True" sorted="False" showDate="True">MC</PhoneBookLocation>
      <!--===== Use this as replacement if you'd like to have Outlook contacts as a phonebook -->
      <!-- PhoneBookLocation id="2" timeout="90" name="Contacts" static="True" shortcut="True" folderPath="Personal Folders\Contacts" encoding="8859-1">OUTLOOK</PhoneBookLocation -->
      <AdditionalInit>*EAPM=3;+CMER=3,2;</AdditionalInit>
      <Keys>
         <Key id="Key_VolUp">u</Key>
         <Key id="Key_VolDown">d</Key>
         <Key id="Key_Up">v</Key>
         <Key id="Key_Down"></Key>
         <Key id="Key_Left">&lt;</Key>
         <Key id="Key_Right">&gt;</Key>
         <Key id="Key_Enter">:J</Key>
         <Key id="Key_Back">:R</Key>
         <Key id="Key_Clear">c</Key>
         <Key id="Key_FK2">]</Key>
         <Key id="Key_FK3">:O</Key>
         <Key id="Key_FK4">:C</Key>
      </Keys>
   </Communication>
   <!-- ===== Section containing the main settings =====-->
   <MainWindow>
      <WindowToSwitchTo/>
      <Ringtone/>
      <SMStone/>
      <CheckPhoneTimeout>20</CheckPhoneTimeout>
      <PopupOnHide position="700,550" size="72,56" opacity="80" backColor="Black" buttonColor="Firebrick">True</PopupOnHide>
   </MainWindow>
   <!-- ===== Section containing the remote settings =====-->
   <RemoteControl>
      <Mode>Server</Mode>
      <IPPort>17015</IPPort>
   </RemoteControl>
   </Texts>
</PhoneControl>
benutze ein T630. nur so am rande. zorro hat mir eine wmp9 keymap geschrieben, mit der ich den wmp steuern kann. funzt ganz gut
NumberOne
BeitragVerfasst: Fr 26 Nov, 2004 18:03  Titel:  (Kein Titel)
Kann man eigentlich mit auch mehrere Befehle hintereinander ausführen lassen? Z.b. ich möchte das die Lautstärke für all 5 Kanäle(hab 5.1 System) mit nur 2 Tasten gesteuert wird. D.h. jeweils eine Tast für 3xVolumeUP und 1 Taste 3xVolumeDown
[ Zeit: 0.8694s ][ Queries: 47 (0.2603s) ][ GZIP Ein - Debug Ein ]
